1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Channel Access Writes Failed on Asyn Record Writable Fields
To: William Lu <[email protected]>
Cc: [email protected]
Date: Tue, 15 Jun 2010 16:22:14 -0400
Can you change the fields locally from the ioc shell (using "dbpf")?
If yes, is Access Security enabled? Do you have write access rights? ("cainfo" on the client machine will tell you.)
Ralph
On Tue 15 Jun 2010 15:39:33 William Lu wrote:
I am having problems with channel access writes on asyn record's writable fields such AOUT and PORT. I created the following asyn tcp/ip port and the asyn record:
In a startup iocsh script:
 drvAsynIPPortConfigure("sockserv","127.0.0.1:9099",0,0,0)
The asyn record:
 record(asyn, LS450PS:asyn) {
 field(DTYP, "asynRecordDevice")
 field(PORT, "sockserv")
 field(ADDR,"0")
After the record has been loaded to the ioc, I cannot write the AOUT or PORT fields of the record through channel access. When I caput on those fields, I got the error messages like the following:
>caput LS450PS:asyn.AOUT "abc"
Old : LS450PS:asyn.AOUT
CA.Client.Diagnostic..............................................
Message: "Could not perform a database value put for that channel"
Severity: "Warning" Context: "detected by: devl17.acc.jlab.org:5064 for: LS450PS:asyn - with request chan=LS450PS:asyn.AOUT op=1 data type=DBR_STRING count=1"
New : LS450PS:asyn.AOUT
What is the problem? Any help would be gratefully appreciated.
William Lu
Jefferson Lab
Re: Channel Access Writes Failed on Asyn Record Writable Fields William Lu
Prev: RE: Channel Access Writes Failed on Asyn Record Writable Fields Mark Rivers
Next: Re: Channel Access Writes Failed on Asyn Record Writable Fields William Lu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Channel Access Writes Failed on Asyn Record Writable Fields Wesley Moore
