I've got it working. I copied your exact configuration so we should be able to determine what is going on with yours. Here's the dbpr after writing to AOUT with caput from another machine. epics> dbpr wmoore:asyn, 2 ACKS: MINOR ACKT: YES ACMD: None ADDR: 0 AINP: AOUT: hey there AQR: 0 ASG: AUCT: autoConnect BAUD: Unknown BINP: 0 BKPT: 00 BOUT: 0 CNCT: Disconnect DBIT: Unknown DESC: DISA: 0 DISP: 0 DISS: NO_ALARM DISV: 1 DRVINFO: DTYP: asynRecordDevice ENBL: Enable EOMR: None ERRS: 0x9ffc160 EVNT: 0 F64INP: 0 F64IV: 0 F64OUT: 0 FCTL: Unknown FLNK:CONSTANT 0 GPIBIV: 0 I32INP: 0 I32IV: 0 I32OUT: 0 IEOS: IFACE: asynOctet IFMT: ASCII IMAX: 80 LCNT: 0 MCTL: Unknown NAME: wmoore:asyn NAWT: 0 NORD: 0 NOWT: 80 NRRD: 0 NSEV: NO_ALARM NSTA: NO_ALARM OCTETIV: 1 OEOS: OFMT: ASCII OMAX: 80 OPTIONIV: 0 PACT: 0 PCNCT: Connect PHAS: 0 PINI: NO PORT: sockserv PRIO: LOW PRTY: Unknown PUTF: 0 REASON: 0 RPRO: 0 SBIT: Unknown SCAN: Passive SDIS:CONSTANT SEVR: MINOR SOCK: SPR: 0 STAT: STATE TB0: On TB1: Off TB2: Off TB3: Off TB4: Off TFIL: Unknown TIB0: Off TIB1: Off TIB2: Off TIME: 2010-06-16 07:24:58.887761646 TINP: TIOM: 0 TMOD: Write/Read TMOT: 1 TMSK: 1 TPRO: 0 TSE: 0 TSEL:CONSTANT TSIZ: 80 UCMD: None UDF: 0 UI32INP: 0 UI32IV: 0 UI32MASK: 4294967295UI32OUT: 0 VAL: Wesley Mark Rivers wrote: - caput again on the LS450PS:asyn.AOUT field gave the same error message as before. begin:vcard fn:Wesley Moore n:Moore;Wesley org:Thomas Jefferson National Accelerator Facility;Free Electron Laser adr:Suite 19, MS 18;;12000 Jefferson Avenue;Newport News;VA;23606;USA email;internet:[email protected] title:FEL Computer Scientist tel;work:(757) 269-6033 tel;fax:(757) 269-6384 tel;pager:(757) 584-6033 url:http://www.jlab.org/FEL/ version:2.1 end:vcard
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
