1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Channel Access Writes Failed on Asyn Record Writable Fields
To: "William Lu" <[email protected]>, "Ralph Lange" <[email protected]>
Cc: [email protected]
Date: Wed, 16 Jun 2010 08:49:24 -0500
Something is wrong, that should work fine.  Here's what I get on a record connected to a VXI11 driver:
epics> dbpf asynRecord.AOUT "test"
DBR_STRING:          "test"
epics> dbpr asynRecord 10
ACKS: NO_ALARM      ACKT: YES           ACMD: None          ADDR: 3
AINP: +1.0071E+21
 AOUT: test          AQR: 0              ASG:
ASP: (nil)          AUCT: autoConnect   BAUD: Unknown       BINP: 0
BKPT: 00            BOUT: 0             CNCT: Connect       DBIT: Unknown
DESC:               DISA: 0             DISP: 0             DISS: NO_ALARM
DISV: 1             DPVT: 0x8acb750     DRVINFO:            DSET: 0x163908
DTYP: asynRecordDevice                  ENBL: Enable        EOMR: End
ERRS: 0x8acba58     EVNT: 0             F64INP: 0           F64IV: 0
F64OUT: 0           FCTL: Unknown       FLNK:CONSTANT 0     GPIBIV: 1
I32INP: 0           I32IV: 1            I32OUT: 0           IEOS:
IFACE: asynOctet    IFMT: ASCII         IMAX: 200           IPTR: 0x8acb958
LCNT: 0             LSET: 0x8aced90     MCTL: Unknown
MLIS: 88 fb b0 08 d8 f6 b0 08 1f 00 00 00                   MLOK: 38 b7 ac 08
NAME: asynRecord    NAWT: 4             NORD: 13            NOWT: 80
NRRD: 0             NSEV: NO_ALARM      NSTA: NO_ALARM      OCTETIV: 1
OEOS:               OFMT: ASCII         OMAX: 40            OPTIONIV: 1
OPTR: 0x8acb928     PACT: 0             PCNCT: Connect      PHAS: 0
PINI: NO            PORT: L0            PPN: (nil)          PPNR: (nil)
PRIO: LOW           PROC: 0             PRTY: Unknown       PUTF: 0
RDES: 0x8aa8db0     REASON: 0           RPRO: 0             RSET: 0x1638c0
SBIT: Unknown       SCAN: Passive       SDIS:CONSTANT       SEVR: NO_ALARM
SOCK:               SPR: 0              SPVT: (nil)         STAT: NO_ALARM
TB0: On             TB1: Off            TB2: Off            TB3: Off
TB4: Off            TFIL: Unknown       TIB0: Off           TIB1: Off
TIB2: Off           TIME: 2010-06-16 08:48:57.406695215
TINP: +1.0071E+21\r\n                   TIOM: 0             TMOD: Write/Read
TMOT: 1             TMSK: 1             TPRO: 0             TSE: 0
TSEL:CONSTANT       TSIZ: 80            UCMD: None          UDF: 0
UI32INP: 0          UI32IV: 0           UI32MASK: 4294967295
UI32OUT: 0          VAL:
Please send the complete output of the following 2 commands:
dbpr LS450PS:asyn 10
asynReport 10 sockserv
Sent: Tue 6/15/2010 4:46 PM
To: Ralph Lange
Subject: Re: Channel Access Writes Failed on Asyn Record Writable Fields
The dbpf does not work.  It gives the error message as below:
epics> dbpf LS450PS:asyn.AOUT abc
filename="../dbTest.c" line number=295
putFields are disabled - dbPutField error
William Lu
Ralph Lange wrote:
> Can you change the fields locally from the ioc shell (using "dbpf")?
> If yes, is Access Security enabled? Do you have write access rights?
> ("cainfo" on the client machine will tell you.)
> Ralph
> On Tue 15 Jun 2010 15:39:33 William Lu wrote:
>> I am having problems with channel access writes on asyn record's
>> writable fields such AOUT and PORT.  I created the following asyn
>> tcp/ip port and the asyn record:
>> In a startup iocsh script:
>>  drvAsynIPPortConfigure("sockserv","127.0.0.1:9099",0,0,0)
>> The asyn record:
>>  record(asyn, LS450PS:asyn) {
>>  field(DTYP, "asynRecordDevice")
>>  field(PORT, "sockserv")
>>  field(ADDR,"0")
>> After the record has been loaded to the ioc, I cannot write the AOUT
>> or PORT fields of the record through channel access.  When I caput on
>> those fields, I got the error messages like the following:
>> >caput LS450PS:asyn.AOUT "abc"
>> Old : LS450PS:asyn.AOUT
>> CA.Client.Diagnostic..............................................
>>    Message: "Could not perform a database value put for that channel"
>>    Severity: "Warning" Context: "detected by:
>> devl17.acc.jlab.org:5064 for: LS450PS:asyn - with request
>> chan=LS450PS:asyn.AOUT op=1 data type=DBR_STRING count=1"
>> New : LS450PS:asyn.AOUT
>> What is the problem?  Any help would be gratefully appreciated.
>> William Lu
>> Jefferson Lab
Weiwei Lu
757-269-7476
[email protected]
Re: Channel Access Writes Failed on Asyn Record Writable Fields William Lu
Re: Channel Access Writes Failed on Asyn Record Writable Fields Ralph Lange
Prev: Re: Channel Access Writes Failed on Asyn Record Writable Fields Wesley Moore
Next: Re: Channel Access Writes Failed on Asyn Record Writable Fields William Lu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Channel Access Writes Failed on Asyn Record Writable Fields William Lu
