epics> dbpf LS450PS:asyn "test" filename="../dbTest.c" line number=295 putFields are disabled - dbPutField error epics> dbpr LS450PS:asyn 10 ACKS: NO_ALARM ACKT: YES ACMD: None ADDR: 0 AINP: AOUT: AQR: 0 ASG: ASP: (nil) AUCT: autoConnect BAUD: Unknown BINP: 0 BKPT: 00 BOUT: 0 CNCT: Connect DBIT: Unknown DESC: DISA: 0 DISP: 0 DISS: NO_ALARM DISV: 1 DPVT: 0x99daeb0 DRVINFO: DSET: (nil) DTYP: asynRecordDevice ENBL: Enable EOMR: None ERRS: 0x99db190 EVNT: 0 F64INP: 0 F64IV: 0 F64OUT: 0 FCTL: Unknown FLNK:CONSTANT 0 GPIBIV: 0 I32INP: 0 I32IV: 0 I32OUT: 0 IEOS: IFACE: asynOctet IFMT: ASCII IMAX: 80 IPTR: 0x99db0e0 LCNT: 0 LSET: 0xfacbe0 MCTL: Unknown MLIS: 00 00 00 00 00 00 00 00 80 81 9d 09 MLOK: 00 00 00 00 NAME: LS450PS:asyn NAWT: 0 NORD: 0 NOWT: 80 NRRD: 0 NSEV: NO_ALARM NSTA: NO_ALARM OCTETIV: 1 OEOS: OFMT: ASCII OMAX: 80 OPTIONIV: 0 OPTR: 0x99db088 PACT: 0 PCNCT: Connect PHAS: 0 PINI: NO PORT: sockserv PPN: (nil) PPNR: (nil) PRIO: LOW PROC: 0 PRTY: Unknown PUTF: 0 RDES: 0xfacc00 REASON: 0 RPRO: 0 RSET: (nil) SBIT: Unknown SCAN: Passive SDIS:CONSTANT SEVR: NO_ALARM SOCK: SPR: 0 SPVT: (nil) STAT: NO_ALARM TB0: On TB1: Off TB2: Off TB3: Off TB4: Off TFIL: Unknown TIB0: Off TIB1: Off TIB2: Off TIME: c8 ba 9d 09 00 00 00 00 TINP: TIOM: 0 TMOD: Write/Read TMOT: 1 TMSK: 1 TPRO: 0 TSE: 0 TSEL:CONSTANT TSIZ: 80 UCMD: None UDF: 0 UI32INP: 0 UI32IV: 0 UI32MASK: 4294967295 UI32OUT: 0 VAL: epics> asynReport 10 sockserv sockserv multiDevice:No canBlock:Yes autoConnect:Yes enabled:Yes connected:Yes numberConnects 1 nDevices 0 nQueued 0 blocked:No asynManagerLock:No synchronousLock:No exceptionActive:No exceptionUsers 2 exceptionNotifys 0 interposeInterfaceList asynOctet pinterface 0xfac6a0 drvPvt 0x99d23a8 interfaceList asynCommon pinterface 0xfab7d4 drvPvt 0x99d1ce0 asynOctet pinterface 0x99d1d28 drvPvt 0x99d1ce0 Port 127.0.0.1:9099: Connected fd: 6 Characters written: 0 Characters read: 0 Thanks, William Mark Rivers wrote: Something is wrong, that should work fine. Here's what I get on a record connected to a VXI11 driver:
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
