1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: XOP
To: "D Peter Siddons" <[email protected]>, "EPICS" <[email protected]>
Date: Fri, 25 Jun 2010 10:52:18 -0500
Hi Pete,
You can always run the 32-bit version of IDL, even if you have a 64-bit machine.  IDL will run the 64-bit version by default, but you can run the 32-bit version with the command
idl -32
From: [email protected] on behalf of D Peter Siddons
Sent: Fri 6/25/2010 10:45 AM
To: EPICS
Subject: XOP
I have not been able to use XOP for some time under Linux due to some
obscure problem between X11 and the XOP virtual machine. In an effort to
overcome this VM issue I bought an IDL license, only to realize that my
new desktop machine (and the IDL I bought) is running 64-bit linux and
all of the binaries underlying XOP are 32-bit.
Is anyone supporting XOP anymore? I don't see any files on the ESRF site
newer than 2007. I see that APS is listed as being an "XOP site". Would
it be possible for someone with appropriate access to update it?
Pete.
XOP D Peter Siddons
Prev: XOP D Peter Siddons
Next: RE: XOP Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
