Hi Pete,
You can 'fix' that libX11 problem by installing a private copy of libX11.so.6.2.0 (taken from an earlier
linux release) into the XOP installation tree and add an extra LD_LIBRARY_PATH to the script that
starts up XOP. It's an ugly solution, I know, but it may be enough for your purposes!
I have an SRPM at http://cep.xor.aps.anl.gov/localpackages/10/SRPMS/xop-2.11-9.fc10.src.rpm that you
could try which has the necessary patches. Or try the RPM at http://cep.xor.aps.anl.gov/localpackages/10/i386/xop-2.11-9.fc10.i386.rpm
Of course, standard caveats apply...
Guy Jennings
On Jun 25, 2010, at 10:45 AM, D Peter Siddons wrote:
> I have not been able to use XOP for some time under Linux due to some obscure problem between X11 and the XOP virtual machine. In an effort to overcome this VM issue I bought an IDL license, only to realize that my new desktop machine (and the IDL I bought) is running 64-bit linux and all of the binaries underlying XOP are 32-bit.
> Is anyone supporting XOP anymore? I don't see any files on the ESRF site newer than 2007. I see that APS is listed as being an "XOP site". Would it be possible for someone with appropriate access to update it?
> Thanks,
> Pete.
- XOP D Peter Siddons
RE: XOP Mark Rivers
Support for Omega CN-7500 temperature controller Xu, Huijuan
<2010>
2025
2026
RE: XOP Mark Rivers
<2010>
2025
2026
