1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: error building latest rtems
To: [email protected]
Cc: RTEMS <[email protected]>, tech-talk <[email protected]>
Date: Sun, 27 Jun 2010 13:00:39 -0400
This is an RTEMS problem and should be directed at their mailing list:
[email protected]
You can configure rtems with --disable-posix (this may break things when trying to build EPICS though...), or apply the proper patch to newlib-1.18.0. You can find this patch in the latest rtems source:
contrib/crossrpms/patches/newlib-1.18.0-rtems4.10-20100402.diff
The problem is that you're using an incompatible patch for newlib-1.18.0. Maybe newlib-1.18.0-rtems4.10-20091218.diff from http://www.rtems.org/ftp/pub/rtems/SOURCES/4.10/ ??
The latest rtems patch for newlib (not sure of the version) includes changes to the "sched_param" structure in libc/include/sys/sched.h, which the latest code in score/posix/src now expects.
HTH
-- dc
On Sun, Jun 27, 2010 at 12:27 PM, Silver <[email protected]> wrote:
hi,
I tried to build rtems cross-compile environment. When I tried to compile the latest rtems (from CVS) with i386-rtems-gcc-4.4.2, I got the following errors:
make[5]: Entering directory `/usr/local/rtems/build/i386-rtems/c/pc386/cpukit/posix'
i386-rtems-gcc --pipe -DHAVE_CONFIG_H   -I.. -I../../cpukit/../../../pc386/lib/include -D__RTEMS_INSIDE__  -Werror=overflow -Werror=pointer-to-int-cast -Werror=int-to-pointer-cast -mtune=i386 -O2 -g -Wall -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT src/libposix_a-pthread.o -MD -MP -MF src/.deps/libposix_a-pthread.Tpo -c -o src/libposix_a-pthread.o `test -f 'src/pthread.c' || echo '../../../../../../rtems-4.10/c/src/../../cpukit/posix/'`src/pthread.c
../../../../../../rtems-4.10/c/src/../../cpukit/posix/src/pthread.c: In function '_POSIX_Threads_Sporadic_budget_TSR':
../../../../../../rtems-4.10/c/src/../../cpukit/posix/src/pthread.c:82: error: 'struct sched_param' has no member named 'sched_ss_init_budget'
../../../../../../rtems-4.10/c/src/../../cpukit/posix/src/pthread.c:109: error: 'struct sched_param' has no member named 'sched_ss_repl_period'
../../../../../../rtems-4.10/c/src/../../cpukit/posix/src/pthread.c: In function '_POSIX_Threads_Sporadic_budget_callout':
../../../../../../rtems-4.10/c/src/../../cpukit/posix/src/pthread.c:132: error: 'struct sched_param' has no member named 'sched_ss_low_priority'
make[5]: *** [src/libposix_a-pthread.o] Error 1
make[5]: Leaving directory `/usr/local/rtems/build/i386-rtems/c/pc386/cpukit/posix'
make[4]: *** [all-recursive] Error 1
make[4]: Leaving directory `/usr/local/rtems/build/i386-rtems/c/pc386/cpukit'
make[3]: *** [all] Error 2
make[3]: Leaving directory `/usr/local/rtems/build/i386-rtems/c/pc386/cpukit'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/usr/local/rtems/build/i386-rtems/c/pc386'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/local/rtems/build/i386-rtems/c'
make: *** [all-recursive] Error 1
make: Leaving directory `/usr/local/rtems/build'
Does anyone has similiar problems? thanks a lot for your help.
Best regards
Geyang  2010-06-28
Re: Re: error building latest rtems Silver
Prev: error building latest rtems Silver
Next: Re: Re: error building latest rtems Silver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
