hi, Daron:
It's ok now. I forgot to re-compile gcc just now.
======= At 2010-06-28, 01:01:00 you wrote: =======
>This is an RTEMS problem and should be directed at their mailing list:
>[email protected]
>You can configure rtems with --disable-posix (this may break things when
>trying to build EPICS though...), or apply the proper patch to
>newlib-1.18.0. You can find this patch in the latest rtems source:
>contrib/crossrpms/patches/newlib-1.18.0-rtems4.10-20100402.diff
><[email protected]>The problem is that you're using an incompatible
>patch for newlib-1.18.0. Maybe newlib-1.18.0-rtems4.10-20091218.diff from
>http://www.rtems.org/ftp/pub/rtems/SOURCES/4.10/ ??
>The latest rtems patch for newlib (not sure of the version) includes changes
>to the "sched_param" structure in libc/include/sys/sched.h, which the latest
>code in score/posix/src now expects.
>HTH
>-- dc
>On Sun, Jun 27, 2010 at 12:27 PM, Silver <[email protected]> wrote:
>> hi,
>> I tried to build rtems cross-compile environment. When I tried to compile
>> the latest rtems (from CVS) with i386-rtems-gcc-4.4.2, I got the following
>> errors:
>> make[5]: Entering directory
>> `/usr/local/rtems/build/i386-rtems/c/pc386/cpukit/posix'
>> i386-rtems-gcc --pipe -DHAVE_CONFIG_H -I..
>> -I../../cpukit/../../../pc386/lib/include -D__RTEMS_INSIDE__
>> -Werror=overflow -Werror=pointer-to-int-cast -Werror=int-to-pointer-cast
>> -mtune=i386 -O2 -g -Wall -Wimplicit-function-declaration -Wstrict-prototypes
>> -Wnested-externs -MT src/libposix_a-pthread.o -MD -MP -MF
>> src/.deps/libposix_a-pthread.Tpo -c -o src/libposix_a-pthread.o `test -f
>> 'src/pthread.c' || echo
>> '../../../../../../rtems-4.10/c/src/../../cpukit/posix/'`src/pthread.c
>> ../../../../../../rtems-4.10/c/src/../../cpukit/posix/src/pthread.c: In
>> function '_POSIX_Threads_Sporadic_budget_TSR':
>> ../../../../../../rtems-4.10/c/src/../../cpukit/posix/src/pthread.c:82:
>> error: 'struct sched_param' has no member named 'sched_ss_init_budget'
>> ../../../../../../rtems-4.10/c/src/../../cpukit/posix/src/pthread.c:109:
>> error: 'struct sched_param' has no member named 'sched_ss_repl_period'
>> function '_POSIX_Threads_Sporadic_budget_callout':
>> ../../../../../../rtems-4.10/c/src/../../cpukit/posix/src/pthread.c:132:
>> error: 'struct sched_param' has no member named 'sched_ss_low_priority'
>> make[5]: *** [src/libposix_a-pthread.o] Error 1
>> make[5]: Leaving directory
>> make[4]: *** [all-recursive] Error 1
>> make[4]: Leaving directory
>> `/usr/local/rtems/build/i386-rtems/c/pc386/cpukit'
>> make[3]: *** [all] Error 2
>> make[3]: Leaving directory
>> make[2]: *** [all-recursive] Error 1
>> make[2]: Leaving directory `/usr/local/rtems/build/i386-rtems/c/pc386'
>> make[1]: *** [all-recursive] Error 1
>> make[1]: Leaving directory `/usr/local/rtems/build/i386-rtems/c'
>> make: *** [all-recursive] Error 1
>> make: Leaving directory `/usr/local/rtems/build'
>> Does anyone has similiar problems? thanks a lot for your help.
>> Best regards
>> Geyang 2010-06-28
Best regards
Geyang 2010-06-28
- error building latest rtems Silver
- Re: error building latest rtems Daron Chabot
error compiling base for rtems Silver
<2010>
2025
2026
<2010>
2025
2026
