1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: aSub Question
To: "Szalata, Zenon M." <[email protected]>
Date: Fri, 2 Jul 2010 18:00:17 -0400
in the snippet you send, INPA is missing a dollar sign for $(P):WF:REQUEST
On 07/02/10 17:38, Szalata, Zenon M. wrote:
I have a waveform and an aSub records. I want to transfer data from the waveform to the aSub record and I am having difficulties with that.
Here is my (simplified) waveform record:
record( waveform, "$(P):WF:REQUEST"){
   field( DESC, "struct for request")
   field( FTVL, "CHAR")
   field( NELM, "132")
   field( FLNK, "$(P):AS:REQUEST")
and here is my aSub record:
record( aSub, "$(P):AS:REQUEST"){
   field( INAM, "asInitialize")
   field( SNAM, "asRequest")
#  field( INPA, "(P):WF:REQUEST")
   field( FTA,  "CHAR")
   field( NOA,  "132")
   field( FTVA, "UCHAR")
   field( NOVA, "132")
When I process the waveform record, the asRequest routine gets called when the INPA field is commented out. However, when I uncomment the INPA field, asRequest routine no longer gets called when the waveform record is processed. Looking at the TIME field in the aSub record I can tell that the records is getting processed each time I process the waveform record, regardless if the INPA field is commented out or not.
Is it not allowed to transfer array of bytes from one record to another?
Is there a way to make that kind of data transfer?
Thanks in advance,
Zen
Matthieu Bec              Gemini Observatory
Tel: +56 51 205785        c/o AURA, Casilla 603
Fax: +56 51 205650        La Serena, Chile
RE: aSub Question Szalata, Zenon M.
Prev: aSub Question Szalata, Zenon M.
Next: Re: aSub Question Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: aSub Question Szalata, Zenon M.
