Hi Zen,
On Friday 02 July 2010 16:38:10 Szalata, Zenon M. wrote:
> I have a waveform and an aSub records. I want to transfer data from the
> waveform to the aSub record and I am having difficulties with that.
> Here is my (simplified) waveform record:
> record( waveform, "$(P):WF:REQUEST"){
> field( DESC, "struct for request")
> field( FTVL, "CHAR")
> field( NELM, "132")
> field( FLNK, "$(P):AS:REQUEST")
> and here is my aSub record:
> record( aSub, "$(P):AS:REQUEST"){
> field( INAM, "asInitialize")
> field( SNAM, "asRequest")
> # field( INPA, "(P):WF:REQUEST")
> field( FTA, "CHAR")
> field( NOA, "132")
> field( FTVA, "UCHAR")
> field( NOVA, "132")
> When I process the waveform record, the asRequest routine gets called when
> the INPA field is commented out. However, when I uncomment the INPA field,
> asRequest routine no longer gets called when the waveform record is
> processed. Looking at the TIME field in the aSub record I can tell that
> the records is getting processed each time I process the waveform record,
> regardless if the INPA field is commented out or not.
Please send us a level 2 dbpr of the aSub record, I'd like to see if it's in
an alarm of any kind and to check some of the other fields.
> Is it not allowed to transfer array of bytes from one record to another?
> Is there a way to make that kind of data transfer?
You should be able to do exactly what you're trying, I don't see anything
obviously wrong with your setup. What architecture are you using, and are you
sure that everything has been compiled and linked using compatible binaries?
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- aSub Question Szalata, Zenon M.
Re: aSub Question Matthieu Bec
RE: aSub Question Szalata, Zenon M.
<2010>
2025
2026
Re: aSub Question Till Straumann
<2010>
2025
2026
