1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Thread model for EPICS on ARM CPU
To: epics Techtalk <[email protected]>
Date: Tue, 06 Jul 2010 12:04:01 -0700
Hi all.
I'm trying to get EPICS running on an ARM CPU. So far I've got a build of EPICS (3.14.10 & 3.14.11) against a glibc 2.3.6 and Linux 2.6.21, where the only thread model supported is linuxthreads (not POSIX/nptl). When I run an IOC, the iocShell crashes (segfault), although the rest of the IOC (asyn device support), and record processing seem to stay running. Is this a reason to suspect the tread model?
I see in the EPICS build commandline, the switch '-D_POSIX_THREADS'. Does this mean a strict POSIX thread model is required?
The iocShell crashes right after iocInit. Running under gdb, I set a breakpoint on iocInit. I see:
(gdb) step Single stepping until exit from function iocshBody, which has no line number information. epics> Program received signal SIGSEGV, Segmentation fault. [Switching to Thread 114696 (LWP 4439)] 0x0006be60 in ca_flush_io ()
Thanks for reading.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada
Re: Thread model for EPICS on ARM CPU Eric Norum
RE: Thread model for EPICS on ARM CPU Hinko Kocevar
Re: Thread model for EPICS on ARM CPU Michael Abbott
Prev: RE: aSub Question Szalata, Zenon M.
Next: Re: Thread model for EPICS on ARM CPU Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
