On Tue, 6 Jul 2010, Rod Nussbaumer wrote:
> I'm trying to get EPICS running on an ARM CPU. So far I've got a build
> of EPICS (3.14.10 & 3.14.11) against a glibc 2.3.6 and Linux 2.6.21,
> where the only thread model supported is linuxthreads (not POSIX/nptl).
> When I run an IOC, the iocShell crashes (segfault), although the rest of
> the IOC (asyn device support), and record processing seem to stay
> running. Is this a reason to suspect the tread model? I see in the EPICS
> build commandline, the switch '-D_POSIX_THREADS'. Does this mean a
> strict POSIX thread model is required?
> The iocShell crashes right after iocInit. Running under gdb, I set a
> breakpoint on iocInit. I see:
> (gdb) step
> Single stepping until exit from function iocshBody,
> which has no line number information.
> epics>
> Program received signal SIGSEGV, Segmentation fault.
> [Switching to Thread 114696 (LWP 4439)]
> 0x0006be60 in ca_flush_io ()
I wouldn't suspect the thread model here.
I have successfully run EPICS on two ARM system architectures, old glibc
with linuxthreads and old ABI and newer glibc with nptl and EABI.
Although the newer glibc and EABI are superiour in many details both
architectures ran EPICS just fine, and I don't remember having to take any
particular precautions.
Regarding the advantage of nptl over linuxthreads, I am aware of an
inadequate implementation of the core synchronisation "compare and set"
functionality in linuxthreads, but that's more of a Hiesenbug with very
low probability of occurrence (requires two interrupts very close together
at precisely the wrong time). This does somewhat depend on your ARM
architecture, I'm working with a PXA ARMv5 processor.
At Diamond we have a build process for generating a complete standalone
busybox based Linux system for ARM with our choice of target system
libraries. This works very well.
- Thread model for EPICS on ARM CPU Rod Nussbaumer
RE: Thread model for EPICS on ARM CPU Hinko Kocevar
RE: Thread model for EPICS on ARM CPU michael.abbott
<2010>
2025
2026
<2010>
2025
2026
