1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: linking to shared objects user libraries
To: "Pierrick Hanlet" <[email protected]>, <[email protected]>
Date: Fri, 9 Jul 2010 09:44:11 -0500
On Linux the linking normally defaults to shared libraries.
In <base>/configure/os/CONFIG_SITE.linux-x86.linux-x86 have you set
SHARED_LIBRARIES=NO and/or STATIC_BUILD=YES?
-----Original Message-----
[mailto:[email protected]] On Behalf Of Pierrick Hanlet
Sent: Friday, July 09, 2010 9:38 AM
To: [email protected]
Subject: linking to shared objects user libraries
I'm using 3.14.11 on a linux machine.  I would like to use several
external (i.e. non-EPICS) .so libraries
in my ioc makefile/  However, the linking appears to default to static
libraries.  According to the applications
developers guide, section 4.6.23.7, I should modify CONFIG_SITE, but
this doesn't work.
What should I do?
Thank you,
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039         office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are
correct" -- Henry Ford
linking to shared objects user libraries Pierrick Hanlet
Prev: linking to shared objects user libraries Pierrick Hanlet
Next: Re: linking to shared objects user libraries J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
