On 7/9/10 9:38 AM, Pierrick Hanlet wrote:
> Hi,
> I'm using 3.14.11 on a linux machine. I would like to use several
> external (i.e. non-EPICS) .so libraries in my ioc makefile/ However,
> the linking appears to default to static libraries. According to the
> applications developers guide, section 4.6.23.7, I should modify
> CONFIG_SITE, but this doesn't work.
> What should I do?
Hi, Pierrick.
Did you try setting both STATIC_BUILD=NO and SHARED_LIBRARIES=YES?
Also, check to make sure your IOC's configuration isn't changing those
variables. If it is, you will need to remove or change them their too.
Lewis
- Re: linking to shared objects user libraries J. Lewis Muir
- Re: linking to shared objects user libraries Pierrick Hanlet
- linking to shared objects user libraries Pierrick Hanlet
RE: linking to shared objects user libraries Mark Rivers
iocStats (was: vxStats memory corruption) Ralph Lange
<2010>
2025
2026
<2010>
2025
2026
