Thanks for the quick responses.
Yes, I did STATIC_BUILD=NO and SHARED_LIBRARIES=YES
in xxx/configure/CONFIG_SITE.
Where might these be overwritten? Also, since I'm using a
mixture of static and shared object libraries, will this
configuration fix me to one type of library or another?
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039 office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
----- Original Message -----
Date: Friday, July 9, 2010 9:50 am
Subject: Re: linking to shared objects user libraries
To: [email protected]
> On 7/9/10 9:38 AM, Pierrick Hanlet wrote:
> > Hi,
> > I'm using 3.14.11 on a linux machine. I would like to use several
> > external (i.e. non-EPICS) .so libraries in my ioc makefile/ However,
> > the linking appears to default to static libraries. According to the
> > applications developers guide, section 4.6.23.7, I should modify
> > CONFIG_SITE, but this doesn't work.
> > What should I do?
> Hi, Pierrick.
> Did you try setting both STATIC_BUILD=NO and SHARED_LIBRARIES=YES?
> Also, check to make sure your IOC's configuration isn't changing those
> variables. If it is, you will need to remove or change them their too.
> Lewis
- RE: linking to shared objects user libraries Mark Rivers
- Re: linking to shared objects user libraries J. Lewis Muir
- linking to shared objects user libraries Pierrick Hanlet
<2010>
2025
2026
<2010>
2025
2026
