1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Getting value of a PV from a subRecord function
To: [email protected]
Date: Fri, 9 Jul 2010 20:53:04 +0200 (CEST)
Hello,
I'm new to EPICS and I've been trying to write some simple programs just
to get to know the software.
Let me start with the database records I'm currently using:
record(bi,"$(user):goSub0") {
	field(DESC,"Start Subroutine0")
	field(DTYP,"Soft Channel")
	field(FLNK,"$(user):stopsub")
	field(ZNAM,"Go0")
	field(ONAM,"Nogo0")
record(bi,"$(user):goSub1") {
	field(DESC,"Start Subroutine1")
	field(ZNAM,"Go1")
	field(ONAM,"Nogo1")
record(sub,"$(user):stopsub") {
	field(DESC,"SimpleTest")
	field(INAM,"SubInit")
	field(SNAM,"TestPrint")
	field(INPA,"$(user):goSub0.VAL")
        field(INPB,"$(user):goSub1.VAL")
The idea is, whenever any of the goSubx changes the TestPrint function
should be called. I'm using MEDM to create a simple GUI, where a button
(Message Button) has its Control Channel set to goSubx.VAL with the press
message set to 1.
As far as I know, this changes the value of goSub whenever I press the
button.
The question is, having the TestPrint function:
long TestPrint(struct subRecord *psu) {
	return 0;
how can I determine which button was pressed? I wanted to check both
inputs and see which goSubx.VAL == 1 but I don't know how to get to the
biRecord pointer using the subRecord pointer. Is there any way to do this?
Thanks in advance for your help.
Kind Regards,
Pawel Predki
Re: Getting value of a PV from a subRecord function Andrew Johnson
Re: Getting value of a PV from a subRecord function Ned Arnold
Prev: Re: linking to shared objects user libraries Andrew Johnson
Next: Re: Getting value of a PV from a subRecord function Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: linking to shared objects user libraries J. Lewis Muir
