1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Getting value of a PV from a subRecord function
To: [email protected]
Date: Fri, 9 Jul 2010 15:13:33 -0500
Hi Pawel,
On Friday 09 July 2010 13:53:04 [email protected] wrote:
> record(sub,"$(user):stopsub") {
>   field(DESC,"SimpleTest")
>   field(INAM,"SubInit")
>   field(SNAM,"TestPrint")
>   field(INPA,"$(user):goSub0.VAL")
>   field(INPB,"$(user):goSub1.VAL")
> The question is, having the TestPrint function:
> long TestPrint(struct subRecord *psu) {
> 	return 0;
> how can I determine which button was pressed? I wanted to check both
> inputs and see which goSubx.VAL == 1 but I don't know how to get to the
> biRecord pointer using the subRecord pointer. Is there any way to do this?
You're not supposed to access the bi records directly, but the two input links
INPA and INPB of the sub record will have already read in the VAL fields of
those records before TestPrint() gets called.  Your function can access the
values read at prec->a and prec->b respectively, and can also set prec->val or
any of the other prec->c through prec->l variables (the ones that don't have
their links set) to export any results.
HTH,
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Getting value of a PV from a subRecord function ppredki
Prev: Getting value of a PV from a subRecord function ppredki
Next: Re: Getting value of a PV from a subRecord function Ned Arnold
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
