1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Another asynPortDriver Question
To: "Szalata, Zenon M." <[email protected]>
Cc: [email protected]
Date: Sun, 11 Jul 2010 16:21:13 -0500
Hi Zen,
> You showed me how to initialize a longout record from a hardware register at iocInit time.
>  I implemented that, as you suggested by creating my version of the virtual function readInt32, and it works fine.
Note that you don't even need to implement your own version of readInt32.  All you need to do is read the value from the hardware register in your constructor and call setIntegerParam with the value.  Then when device longout support calls the asynPortDriver::readInt32 function during initialization it will get the current value, and will get an asynSuccess return.  If you have not called setIntegerParam before iocInit then asynPortDriver::readInt32 will return asynError, and the longout device support will not initialize the record to that value.
> How can I modify the contents of a longout record from the low level driver code at run time?
> I am developing a low level asyn driver derived from asynPortDriver class and it became of interest to me to do that.
> I think that I could accomplish this using dbAccess routines, but that seems somewhat inelegant.
I would recommend doing it in the database.  Here is an example of how I do it.  There are 2 longout records, one with soft device support and one with asyn device support.  There is a longin record on the same parameter with SCAN=I/O Intr.  When your driver does setIntegerParam() and callParamCallbacks() this longin record processes.  It writes the value into the soft longout record, which writes it to the asyn longout.  But the asyn longout does not process because of the configuration of SDIS and DISV, so your driver is not called.  This has the effect of synchronizing the longout to the driver value any time the driver changes it.
record(longout, "$(P)$(R)FileNumber")
    field(PINI, "YES")
    field(OUT, "$(P)$(R)FileNumber_write PP")
    field(VAL, "1")
record(longout, "$(P)$(R)FileNumber_write")
    field(SDIS, "$(P)$(R)FileNumber_Sync.PACT")
    field(DISV, "1")
    field(DTYP, "asynInt32")
    field(OUT, "@asyn($(PORT),$(ADDR),$(TIMEOUT))FILE_NUMBER")
record(longin, "$(P)$(R)FileNumber_RBV")
    field(INP,  "@asyn($(PORT),$(ADDR),$(TIMEOUT))FILE_NUMBER")
    field(SCAN, "I/O Intr")
    field(FLNK, "$(P)$(R)FileNumber_Sync")
record(longout, "$(P)$(R)FileNumber_Sync")
    field(DOL,  "$(P)$(R)FileNumber_RBV NPP")
    field(OMSL, "closed_loop")
    field(OUT,  "$(P)$(R)FileNumber PP")
Sent: Sun 7/11/2010 3:53 PM
To: Mark Rivers
Subject: Another asynPortDriver Question
Hi Mark,
You showed me how to initialize a longout record from a hardware register at iocInit time.  I implemented that, as you suggested by creating my version of the virtual function readInt32, and it works fine.
I now have a related question.
How can I modify the contents of a longout record from the low level driver code at run time?  I am developing a low level asyn driver derived from asynPortDriver class and it became of interest to me to do that.  I think that I could accomplish this using dbAccess routines, but that seems somewhat inelegant.
Thanks in advance,
Zen
RE: Another asynPortDriver Question Wang Xiaoqiang
Another asynPortDriver Question Szalata, Zenon M.
Prev: Another asynPortDriver Question Szalata, Zenon M.
Next: RE: linking to shared objects user libraries Andrew C. Starritt
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Another asynPortDriver Question Wang Xiaoqiang
