1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Using Motor Record with READBACK Deadband and number of Retries.
To: "Rarback, Harvey M." <[email protected]>
Cc: Tech-talk <[email protected]>
Date: Thu, 15 Jul 2010 20:34:59 -0700
Sent from my iPhone
On Jul 15, 2010, at 16:32, "Rarback, Harvey M." <[email protected]> wrote:
>    Ernest,
>> We are currently using "Motor Record Version 5.9"
>> on some of our stepper motor applications.
>> We would like to use the motor software with USE READBACK enabled.
>> We are connecting our calibrated LVDT to the READBACK link.
>> What has been your experience in using this feature of the Motor Record?
> At SPEAR we are using motor record 6.22.  All our motors use the readback link to external encoders.  Although we have had some issues with callbacks going astray with soft motors (ask Till!), the external readback links seem to work ok.
I will try upgrading
>> When using READBACK inlink for Motor position sensing:
>> (1) Selecting YES/NO does not update the motor record properly.
>> Should the software actually copy the contents of MOTOR.VAL to MOTOR.RBV
>> If READBACK is toggled back to "NO"
>> If the READBACK is set to "YES" then "MOTOR.RDBL", should be copied to
>> MOTOR.RBV ?
> I believe your problem is "YES" is not equal to "Yes".  It bit me too ;-)
I am not using caput. I am using the motor screens from the APS
In my email I only mean to state true or false :)
>                                  --Harvey
Using Motor Record with READBACK Deadband and number of Retries. Ernest L. Williams Jr.
RE: Using Motor Record with READBACK Deadband and number of Retries. Rarback, Harvey M.
Prev: Re: devGpib problem Eric Norum
Next: Soft IOC on Windows PC Gorka Ronda
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Using Motor Record with READBACK Deadband and number of Retries. Rarback, Harvey M.
Next: Re: Using Motor Record with READBACK Deadband and number of Retries. Ron Sluiter
