Hello Ernest,
There is a feedback data flow diagram here
on page #17 that may clarify how the motor record feedback works.
Ron
Ernest L. Williams Jr. wrote:
We are currently using "Motor Record Version 5.9"
on some of our stepper motor applications.
We would like to use the motor software with USE READBACK enabled.
We are connecting our calibrated LVDT to the READBACK link.
What has been your experience in using this feature of the Motor
Record?
When using READBACK inlink for Motor position sensing:
(1) Selecting YES/NO does not update the motor record properly.
Should the software actually copy the contents of MOTOR.VAL to
MOTOR.RBV
If READBACK is toggled back to "NO"
If the READBACK is set to "YES" then "MOTOR.RDBL", should be copied to
MOTOR.RBV ?
Thanks in Advance,
Ernest
SLAC
- Re: Using Motor Record with READBACK Deadband and number of Retries. Ernest L. Williams Jr.
- Using Motor Record with READBACK Deadband and number of Retries. Ernest L. Williams Jr.
RE: areaDetector problem John Dobbins
<2010>
2025
2026
<2010>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
