1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: devGpib problem
To: [email protected]
Date: Fri, 16 Jul 2010 11:24:57 -0500
Some parts of APS have these separated but most put them together on the same subnet.
On 07/16/2010 10:58 AM, [email protected] wrote:
On 18:17 Thu 15 Jul , Mark Rivers wrote:
Shifu's device is a TCP/IP power supply, talking a simple ASCII
protocol.  When talking to the device it usually responds quickly, but
occasionally the responses are very delayed.  Whether this is due to the
device or to the APS network is not clear, but in any event sometimes
the response does not occur until after the 2 second timeout specified
in the devGpib file.  However, the device does appear to always
eventually reply.
I have similar problems with a few of my networked devices. In my case, I believe this is due to broadcast packets. A (logical or physical) point to point connection (device<-> IOC ) solve that problem. I believe the broadcast packets are nothing less than the CA protocol itself ;-) In a perfect world, one should have a network with OPIs and another network for controlled devices. The IOCs are the bridges between both networks.
At APS, are controlled devices and OPIs on the same net?
Re: devGpib problem Ralph Lange
devGpib problem Mark Rivers
Re: devGpib problem emmanuel_mayssat
Prev: Striptool with no PV emmanuel_mayssat
Next: Re: devGpib problem Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: devGpib problem emmanuel_mayssat
