1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: devGpib problem
To: Ron Sluiter <[email protected]>
Cc: [email protected]
Date: Fri, 16 Jul 2010 13:03:01 -0500
Ron,
It is TCP/IP communication between the power supply and IOC, the device
support is devGpib.
Shifu
On Fri, 2010-07-16 at 12:54 -0500, Ron Sluiter wrote:
> Mark,
> I'm confused, you said Shifu has "a problem talking to a power supply
> using devGpib".
> But then you said, "Shifu's device is a TCP/IP power supply" and "This
> stale response
> is read by the TCP driver".
> What is the communication connect to EPICS; GPIB or ethernet?
> Ron
> Mark Rivers wrote:
> > Folks,
> > I was helping Shifu Xu from APS debug a problem talking to a power
> > supply using devGpib today, and I think I've found a problem with
> > devGpib.  I have never used devGpib myself, so I could be mistaken.
> > Shifu's device is a TCP/IP power supply, talking a simple ASCII
> > protocol.  When talking to the device it usually responds quickly, but
> > occasionally the responses are very delayed.  Whether this is due to the
> > device or to the APS network is not clear, but in any event sometimes
> > the response does not occur until after the 2 second timeout specified
> > in the devGpib file.  However, the device does appear to always
> > eventually reply.
> > The records in question are input records (volts, current, status, etc.)
> > that are periodically processing, and each sends a query and reads the
> > response.
> > The problem occurs when there is a timeout.  The device does eventually
> > send the requested response.  This stale response is read by the TCP
> > driver.  The devGpib driver does not appear to do a "flush" before it
> > does its atomic write/read operation.  Because it does not do a flush,
> > it does a write, but then when it does a read it does not get the new
> > data from the device, but rather it gets the stale response to a
> > previous command.  Because it is getting stale data, it is not even
> > necessarily the response to the correct command, so volts are getting
> > read as current, etc.
> > It would seem to me that this is really a bug in devGpib, and it should
> > always flush any stale data from the port driver before it does the
> > Is there anyone more familiar than I with devGpib who can comment on
> > this?
> > Who is taking ownership for devGpib?  It is part of asyn, for which I am
> > nominally the contact person, but I really don't want to maintain
> > devGpib.
> > Eric?
> > Thanks,
> > Mark
devGpib problem Mark Rivers
Re: devGpib problem Ron Sluiter
Prev: Re: devGpib problem Ron Sluiter
Next: Re: devGpib problem Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
