"devGpib" is a bit of a historical artifact. The device support provided by that module can communicate with devices using GPIB, serial ports or ethernet (raw TCP or VXI-11). For example, the Tektronix TDS-3000 oscilloscope support has been used to communicate with these scopes using:
A local GPIB interface (NI-1014)
A LAN/GPIB adapter
A local serial port
A LAN/RS-232 adapters
A direct network connection
On Jul 16, 2010, at 10:54 AM, Ron Sluiter wrote:
> Mark,
> I'm confused, you said Shifu has "a problem talking to a power supply using devGpib".
> But then you said, "Shifu's device is a TCP/IP power supply" and "This stale response
> is read by the TCP driver".
> What is the communication connect to EPICS; GPIB or ethernet?
> Ron
Eric Norum
[email protected]
- devGpib problem Mark Rivers
- Re: devGpib problem Ron Sluiter
Re: devGpib problem Shifu Xu
video lag John Dobbins
<2010>
2025
2026
Re: devGpib problem Rod Nussbaumer
<2010>
2025
2026
