Hi Pawel,
>I've started using the CSS ennvironment and BOY for creating GUIs but
>I've come across a problem with macro substitution.
Thanks for using BOY and ask the questions!
>I'm creating a GUI for a data acquisition system which consists of
>several DAQ boards. My aim is to have only one XY graph visible at once
>on the screen and be able to switch between them using, for example,
>action buttons.
There may be other options which can make this task easier: using Tab widget or change the pv name of a trace from action button via script.
>However, when I specify the macro value for the whole display I am not able to change
>it using the action buttons. Somehow, the display macro value definition
>trumps the one given by the action button.
The macros property cannot be changed via script during runtime. It is only loaded once during opi startup. The display macros will replace the same one from its parents.
>The only way I was able to make it work was not specifying any display
>macro value. This, however, results in an ugly first screen where all
>the controls are disconnected since the macro is undefined. Clicking one
>of the action buttons connects to the correct card.
Still cannot understand that clearly. Could you send me the opi files?
Xihui
- CSS/BOY macro substitution problem PaweÅ PrÄdki
Problem with streamDevice and I/O Intr Florian Feldbauer
RE: CSS/BOY macro substitution problem Chen, Xihui
<2010>
2025
2026
<2010>
2025
2026
