I ran into a problem when reading from a serial device using I/O Intr processing with streamDevice. I receive 64 messages in series and have one record for each message. Now and then I get the error message from epics: timerQueue INTERNAL ERROR (PANDA:FEMC:PROTO192:THMP:680:CHK:00): timerExpired() unexpected ioAction None Any idea how to fix this problem? This is the db:
record (scalcout, "THMP:$(ID):CHK:$(no)")
field (DTYP, "stream")
field (SCAN, "I/O Intr")
field (CALC, "((K XOR L) XOR C)==E?(K<<8)+L:LL")
field (OUT, "@THMP.proto getMsg($(no)) USBCAN1")
field (INPC, "$(no)")
field (INLL, "INV CHK")
}This is the protocol:
Terminator = CR;
getMsg{
in "t6804\${2}%(K)2X%(L)2X%(E)2X";
}This is an example string, which is sent from the device: t68043F34AAA1\r Best regards Florian
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
