It should be there in the built-in help with the entry " CSS Applications->Display->Best OPI, Yet->Rules". If it is not there, you may need to download the latest version.
Cheers,
Xihui
Sent: Thursday, August 05, 2010 11:15 AM
To: Chen, Xihui
Cc: [email protected]
Subject: Re: CSS/BOY macro substitution problem
Hi Xihui,
I was sure I did use the BOY preference settings to set the default
macro value but apparently I didn't. Thanks for that solution - it works
the way I want it to.
The second issue has been resolved as well. Thank you. However, I was
wondering whether the rules were documented somewhere? I couldn't find
anything about them in the built-in help documentation.
Cheers,
Pawel
On 05.08.2010 17:03, Chen, Xihui wrote:
> Hi Pawel,
> You can give the default global macros from BOY preference settings, which can be set from menu CSS->Preference->CSS-Applications->Display->BOY. If you set cardno = 0 at here, I think your mainScreen will work as you wanted.
> If you don't want to be bothered by Javascript, you can use rules for most of dynamic behavior needs. Please see attachment how the rule can invisble a group widget based on the selection in a combo box.
> Thanks,
> Xihui
> From: Paweł Prędki [[email protected]]
> Sent: Thursday, August 05, 2010 10:32 AM
> To: Chen, Xihui
> Here you go. Hopefully, it gets through this time.
> On 05.08.2010 16:22, Chen, Xihui wrote:
>> The attachment is blocked. Could you send them again by compress them in a zip file?
>> Thanks,
>> Xihui
>> Sent: Thursday, August 05, 2010 10:00 AM
>> To: Chen, Xihui
>> Hi Xihui,
>> Thanks for such a quick answer. Please find the .opi files attached to
>> this message.
>>> Hi Pawel,
>>>> I've started using the CSS ennvironment and BOY for creating GUIs but
>>>> I've come across a problem with macro substitution.
>>> Thanks for using BOY and ask the questions!
>>>> I'm creating a GUI for a data acquisition system which consists of
>>>> several DAQ boards. My aim is to have only one XY graph visible at once
>>>> on the screen and be able to switch between them using, for example,
>>>> action buttons.
>>> There may be other options which can make this task easier: using Tab widget or change the pv name of a trace from action button via script.
>> I don't really want to use the Tab widget and copy the same setup
>> (mainScreen) to all the tabs and changing the names of the PVs connected
>> to the widgets. This will require many manual changes if I want to add
>> another DAQ card, for example. Macros work perfectly in this case.
>> Changing the trace pv name via script could be a good solution but I
>> have little experience with JavaScript. On the other hand, I still use
>> the macro value in other screens so I would like to keep it.
>>>> However, when I specify the macro value for the whole display I am not able to change
>>>> it using the action buttons. Somehow, the display macro value definition
>>>> trumps the one given by the action button.
>>> The macros property cannot be changed via script during runtime. It is only loaded once during opi startup. The display macros will replace the same one from its parents.
>>>> The only way I was able to make it work was not specifying any display
>>>> macro value. This, however, results in an ugly first screen where all
>>>> the controls are disconnected since the macro is undefined. Clicking one
>>>> of the action buttons connects to the correct card.
>>> Still cannot understand that clearly. Could you send me the opi files?
>> When you run the mainScreen.opi the $(cardno) macro is not expanded
>> because it is not defined at the global level. Clicking one of the CARD
>> buttons replaces the current mainScreen with the same screen but with
>> the $(cardno) macro defined. I would like to start the application with,
>> for example, cardno=0 and then change it according to the button
>> pressed. It was possible in EDM.
>> Also, maybe you are able to answer another question. In the GroupConfig
>> screen there is a group of controls (Signal Amplitude, Signal Phase)
>> that I want to become invisible if one of the options in the nearby
>> Combobox is chosen. Is it necessary to use JavaScript to do so? Would
>> you be able to give me a hint how to do this?
>>> Thanks,
>>> Xihui
>> Thanks,
>> Pawel
- CSS/BOY macro substitution problem PaweÅ PrÄdki
- RE: CSS/BOY macro substitution problem Chen, Xihui
- Re: CSS/BOY macro substitution problem PaweÅ PrÄdki
Making a case for cases Steiner, Mathias
<2010>
2025
2026
Problem with streamDevice and I/O Intr Florian Feldbauer
<2010>
2025
2026
