Hi Dirk,
your guess is correct. The USBCAN maps as /dev/tty on our system.
At the moment I read out my device every 10 seconds.
That means every 10 seconds a bunch of 64 messages are send from the
device.
Within such a bunch every 276 us one message is send.
Florian
On Thu, 12 Aug 2010, Dirk Zimoch wrote:
Hi Florian,
I have to set up a test system to find out what's wrong. That might take a
while. I guess your USBCAN mapps to a /dev/tty... on your system (like a
standard sreial device?).
At which rate do you get these messages?
Dirk
Florian Feldbauer wrote:
Dear Dirk,
The device is custom hardware. The CAN messages come from a AT90CAN64
microcontroller with a PCA82C250 CAN transceiver.
http://www.atmel.com/dyn/resources/prod_documents/doc7679.pdf
This mircocontroller send one message after another.
They all look like "t6804NODDDDCH\r" where NO is the channelnumber (0-63),
DDDD the appropriate 14-bit conversion result from the ADC and CH
an 8-bit checksum. All coded in hexadecimal
The baudrate of the CAN bus is set to 1 Mbaud.
Florian
On Tue, 10 Aug 2010, Dirk Zimoch wrote:
> Hi Florian,
> Looks like a race condition. I have to look in the driver. I fear there
> is nothing you can do about it.
> How does the communication work? You say you get 64 messages in series.
> What do they look like? All like "t68043F34AAA1\r" (only difference in
> $(no))? That is the timing of these messages? Do they all come in one
> burst? Do you have a link to the device documentation?
> Dirk
> > Hello all,
> > I ran into a problem when reading from a serial device using I/O Intr
> > processing with streamDevice. I receive 64 messages in series and have
> > one record for each message.
> > Now and then I get the error message from epics:
> > timerQueue INTERNAL ERROR (PANDA:FEMC:PROTO192:THMP:680:CHK:00):
> > timerExpired() unexpected ioAction None
> > Any idea how to fix this problem?
> > This is the db:
> > record (scalcout, "THMP:$(ID):CHK:$(no)")
> > field (DTYP, "stream")
> > field (SCAN, "I/O Intr")
> > field (CALC, "((K XOR L) XOR C)==E?(K<<8)+L:LL")
> > field (OUT, "@THMP.proto getMsg($(no)) USBCAN1")
> > field (INPC, "$(no)")
> > field (INLL, "INV CHK")
> > This is the protocol:
> > Terminator = CR;
> > getMsg{
> > in "t6804\${2}%(K)2X%(L)2X%(E)2X";
> > This is an example string, which is sent from the device:
> > t68043F34AAA1\r
> > Best regards
> > Florian
| Florian Feldbauer |
| Ph.D. student |
| Institut für Experimentalphysik I |
| Ruhr-Universität Bochum |
| Universitätsstr. 150 |
| D-44780 Bochum |
| Office: NB 2/172 |
| Phone: (+49)234 / 32-23537 |
| Fax: (+49)234 / 32-14170 |
| Web: http://www.ep1.rub.de |
- Problem with streamDevice and I/O Intr Florian Feldbauer
- Re: Problem with streamDevice and I/O Intr Dirk Zimoch
- Re: Problem with streamDevice and I/O Intr Florian Feldbauer
Re: devIocStats 3.1.3 released Ralph Lange
<2010>
2025
2026
FW: Making a case for cases Steiner, Mathias
<2010>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
