1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: IOC Build Error
To: "Andrew Wagner" <[email protected]>, <[email protected]>
Date: Fri, 13 Aug 2010 23:16:13 -0500
Make sure you do a "make clean" at the top level of your application, or in the configure/ directory after editing configure/RELEASE.
Sent: Fri 8/13/2010 8:48 PM
To: [email protected]
Subject: IOC Build Error
Hi everyone,
I'm having trouble creating an IOC application that includes device support for several different devices. I would like to be able to read inputs from one device and based on that, write output to a second device. As a first step I have created device support in /Users/andrewwagner/ASYN/instruments/ag34970 (my local machine) that I have successfully tested. I am creating my application in /Users/andrewwagner/ASYN/applications/MagnetCtrl . I have the lines:
# Asyn and Device Support
ASYN=/Users/andrewwagner/ASYN/asyn4-13-1
AG34970=/Users/andrewwagner/ASYN/asyn4-13-1/instruments/ag34970
# EPICS_BASE usually appears last so other apps can override stuff:
EPICS_BASE=/Users/andrewwagner/EPICS/base-3-14-11
in my config/RELEASE and I need to know the location of devAG34970.dbd located in AG34970/dbd . When I run make in MagnetCtrl to build my application I get the error:
Expanding dbd
/Users/andrewwagner/EPICS/base-3-14-11/bin/darwin-x86/dbExpand  -I . -I .. -I ../../../dbd -I/Users/andrewwagner/ASYN/asyn4-13-1/dbd  -I/Users/andrewwagner/EPICS/base-3-14-11/dbd -o ../O.Common/MagnetCtrl.dbd ../O.Common/MagnetCtrlInclude.dbd
Can't open include file "devAG34970.dbd"
Error at or before ""devAG34970.dbd"" in file "../O.Common/MagnetCtrlInclude.dbd" line 3
Based on the message it seems that both ASYN and EPICS_BASE were properly included but AG34970 was not. I must be doing something wrong but can't figure out why it can't find devAG34970.dbd . In brief I'm trying to build an ioc where the device support is located in some other directory but am having trouble with the Makefile rules. Thanks very much for your help.
Andrew
Re: IOC Build Error Andrew Wagner
Prev: Re: IOC Build Error Ernest L. Williams
Next: RE: ASYN Addition Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: IOC Build Error Andrew Wagner
