1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IOC Build Error
To: Andrew Wagner <[email protected]>
Date: Fri, 13 Aug 2010 19:07:35 -0700
Hi
The path may be case sensitive
Make sure the path is absolutely correct for the location of your dbd file
In your post, I see uppercase AG versus lower case ag
HTH
Ernesto
Sent from my iPhone
On Aug 13, 2010, at 18:48, Andrew Wagner <[email protected]> wrote:
> Hi everyone,
> I'm having trouble creating an IOC application that includes device support for several different devices. I would like to be able to read inputs from one device and based on that, write output to a second device. As a first step I have created device support in /Users/andrewwagner/ASYN/instruments/ag34970 (my local machine) that I have successfully tested. I am creating my application in /Users/andrewwagner/ASYN/applications/MagnetCtrl . I have the lines:
> # Asyn and Device Support
> ASYN=/Users/andrewwagner/ASYN/asyn4-13-1
> AG34970=/Users/andrewwagner/ASYN/asyn4-13-1/instruments/ag34970
> # EPICS_BASE usually appears last so other apps can override stuff:
> EPICS_BASE=/Users/andrewwagner/EPICS/base-3-14-11
> in my config/RELEASE and I need to know the location of devAG34970.dbd located in AG34970/dbd . When I run make in MagnetCtrl to build my application I get the error:
> Expanding dbd
> /Users/andrewwagner/EPICS/base-3-14-11/bin/darwin-x86/dbExpand  -I . -I .. -I ../../../dbd -I/Users/andrewwagner/ASYN/asyn4-13-1/dbd  -I/Users/andrewwagner/EPICS/base-3-14-11/dbd -o ../O.Common/MagnetCtrl.dbd ../O.Common/MagnetCtrlInclude.dbd
> Can't open include file "devAG34970.dbd"
> Error at or before ""devAG34970.dbd"" in file "../O.Common/MagnetCtrlInclude.dbd" line 3
> Based on the message it seems that both ASYN and EPICS_BASE were properly included but AG34970 was not. I must be doing something wrong but can't figure out why it can't find devAG34970.dbd . In brief I'm trying to build an ioc where the device support is located in some other directory but am having trouble with the Makefile rules. Thanks very much for your help.
> Andrew
IOC Build Error Andrew Wagner
Prev: IOC Build Error Andrew Wagner
Next: RE: IOC Build Error Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
