1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: DataBase question
To: "Andrew Wagner" <[email protected]>, <[email protected]>
Date: Mon, 16 Aug 2010 14:12:30 -0500
> Do records loaded in the same IOC have access to each others PVs
Yes.
But you are not restricted to the same IOC, records in one IOC can
access records in other IOCs as well.  There are some restrictions, but
records can both read and write PVs in other IOCs.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Andrew Wagner
Sent: Monday, August 16, 2010 2:05 PM
To: [email protected]
Subject: DataBase question
Hey guys,
I'm building a database to ramp a magnet given inputs from an Agilent
34970 MUX and output to an Agilent 3631 Voltage programmer. I've got the
drivers and device support working for the MUX and programmer and would
like to create a database (and separate application) that can access the
AI and AO records from the devices and and perform calculations. My
question is: Do records loaded in the same IOC have access to each
others PVs? For instance if I :
dbLoadRecords("db/devAG34970.db",args)
dbLoadRecords("db/devAG3631.db",args)
to load the AI and AO records for the devices, can I have a third
record,
dbLoadRecords("db/MagnetCtrl.db",args)
that contains calc records that have inputs from pvs defined in the
devAG records? Alternatively, do I have to define one big record that
includes everything I want.
Cheers,
Andrew
DataBase question Andrew Wagner
Prev: DataBase question Andrew Wagner
Next: Re: DataBase question Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
