1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Asyn and I/O intr scanning
To: [email protected]
Date: Tue, 17 Aug 2010 16:44:30 +0200
I've created a device support for simple GPIB according to the
http://www.aps.anl.gov/epics/modules/soft/asyn/R4-14/HowToDoSerial/tutorial.pdf
guide. I can get the data from the device as expected.
Versions: EPICS R3.14.10, Asyn 4-14.
I've added the SCAN field to my record:
record(stringin, "$(P)$(R)VOL:N5V")
	field(DESC, "Read -5V voltage")
	field(DTYP, "RFClock")
	field(INP,  "#L$(L) A$(A) @4")
	field(SCAN, "I/O Intr")
At IOC startup I get following message:
PV: FOO:BAR:VOL:N5V scanAdd: I/O Intr not valid (no get_ioint_info)
After Googling a bit I found some pointers in 4_3_DeviceSupport_APS.pdf,
but I'm a bit confused how to actually implement modification in my
device support.
If I understand correctly, I need to setup my own DSET with the
get_ioint_info being defined. Done that:
static long get_ioint_info (int cmd, struct stringinRecord *si,
IOSCANPVT *ppvt)
	printf("%s:%d ENTER\n", __FUNCTION__, __LINE__);
	return 0;
static gDset DSET_SI_IOSCAN = {
	6,
	{0, 0, devGpib_initSi, get_ioint_info, devGpib_readSi, 0},
	&devSupParms
epicsExportAddress(dset,DSET_SI_IOSCAN);
Modified the struct gpibCmd gpibCmds[] = {
/* Param 4 - Read the -5V voltage */
/*{&DSET_SI, GPIBREAD, IB_Q_HIGH, "VOL:N5V?", "VOL:N5V %s\r\nOK", 0, 80,
NULL, 0, 0, NULL, NULL, NULL},*/
{&DSET_SI_IOSCAN, GPIBREAD, IB_Q_HIGH, "VOL:N5V?", "VOL:N5V %s\r\nOK",
0, 80, NULL, 0, 0, NULL, NULL, NULL},
Now at IOC startup I get following messages:
FOO:BAR:VOL:N5V : init_record : record type invalid for spec'd GPIB param#4
Not really sure what needs to done from here on.
Best regards,
Hinko
Hinko Kocevar
Technical support software engineer
Instrumentation Technologies d.d.
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the addressee and may
contain confidential and/or privileged information. Any review, retention,
disclosure or other use by persons other than the intended recipient is
prohibited. If you received this in error, please notify the sender and
delete all copies.
Re: Asyn and I/O intr scanning Eric Norum
Prev: some patches for msi Benjamin Franksen
Next: Re: Asyn and I/O intr scanning Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
