Have a look at the 'SRQ Processing' section of the devGpib documentation (<asyn>/documentation/devGpib.pdf). The command table type element should be GPIBREADW (or one of the other GPIBxxxxxxW values) which waits for the device to issue a SRQ then performs the read (or write) operation.
You do not have to use get_ioint_info yourself -- the devGpib code handles this.
On Aug 17, 2010, at 7:44 AM, Hinko Kocevar wrote:
> Hi,
> I've created a device support for simple GPIB according to the
> http://www.aps.anl.gov/epics/modules/soft/asyn/R4-14/HowToDoSerial/tutorial.pdf
> guide. I can get the data from the device as expected.
> Versions: EPICS R3.14.10, Asyn 4-14.
> I've added the SCAN field to my record:
> record(stringin, "$(P)$(R)VOL:N5V")
> field(DESC, "Read -5V voltage")
> field(DTYP, "RFClock")
> field(INP, "#L$(L) A$(A) @4")
> field(SCAN, "I/O Intr")
> At IOC startup I get following message:
> PV: FOO:BAR:VOL:N5V scanAdd: I/O Intr not valid (no get_ioint_info)
> After Googling a bit I found some pointers in 4_3_DeviceSupport_APS.pdf,
> but I'm a bit confused how to actually implement modification in my
> device support.
> If I understand correctly, I need to setup my own DSET with the
> get_ioint_info being defined. Done that:
> static long get_ioint_info (int cmd, struct stringinRecord *si,
> IOSCANPVT *ppvt)
> printf("%s:%d ENTER\n", __FUNCTION__, __LINE__);
> return 0;
> static gDset DSET_SI_IOSCAN = {
> 6,
> {0, 0, devGpib_initSi, get_ioint_info, devGpib_readSi, 0},
> &devSupParms
> epicsExportAddress(dset,DSET_SI_IOSCAN);
> Modified the struct gpibCmd gpibCmds[] = {
> /* Param 4 - Read the -5V voltage */
> /*{&DSET_SI, GPIBREAD, IB_Q_HIGH, "VOL:N5V?", "VOL:N5V %s\r\nOK", 0, 80,
> NULL, 0, 0, NULL, NULL, NULL},*/
> {&DSET_SI_IOSCAN, GPIBREAD, IB_Q_HIGH, "VOL:N5V?", "VOL:N5V %s\r\nOK",
> 0, 80, NULL, 0, 0, NULL, NULL, NULL},
> Now at IOC startup I get following messages:
> FOO:BAR:VOL:N5V : init_record : record type invalid for spec'd GPIB param#4
> Not really sure what needs to done from here on.
> Best regards,
> Hinko
> Hinko Kocevar
> Technical support software engineer
> Instrumentation Technologies d.d.
> Velika pot 22, SI-5250 Solkan - Slovenia
> T:+386 5 3352600, F:+386 5 3352601
> mailto: [email protected]
> http://www.i-tech.si - When your users demand stability
> The information transmitted is intended solely for the addressee and may
> contain confidential and/or privileged information. Any review, retention,
> disclosure or other use by persons other than the intended recipient is
> prohibited. If you received this in error, please notify the sender and
> delete all copies.
Eric Norum
[email protected]
- Re: Asyn and I/O intr scanning Hinko Kocevar
- Asyn and I/O intr scanning Hinko Kocevar
Re: Asyn and I/O intr scanning Eric Norum
<2010>
2025
2026
<2010>
2025
2026
