1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Asyn and I/O intr scanning
To: Eric Norum <[email protected]>
Cc: [email protected]
Date: Thu, 19 Aug 2010 13:01:53 +0200
Hi Eric,
On 08/17/10 17:44, Eric Norum wrote:
> Have a look at the 'SRQ Processing' section of the devGpib documentation (<asyn>/documentation/devGpib.pdf).  The command table type element should be GPIBREADW (or one of the other GPIBxxxxxxW values) which waits for the device to issue a SRQ then performs the read (or write) operation.
> You do not have to use get_ioint_info yourself -- the devGpib code handles this.
I've tried using
{&DSET_SI, GPIBREADW, IB_Q_HIGH, "VOL:N5V?", "VOL:N5V %s\r\nOK", 0, 80,
NULL, 0, 0, NULL, NULL, NULL},
But the IOC says:
2010/08/19 12:39:19.606 FOO:BAR:VOL:N5V parm 4 gpibCmd.type requires
asynGpib but it is not implemented by port driver
PV: FOO:BAR:VOL:N5V scanAdd: I/O Intr not valid (no get_ioint_info)
Do I need to add/change anything else?
Thank you!
Hinko
Hinko Kocevar
Technical support software engineer
Instrumentation Technologies d.d.
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the addressee and may
contain confidential and/or privileged information. Any review, retention,
disclosure or other use by persons other than the intended recipient is
prohibited. If you received this in error, please notify the sender and
delete all copies.
Re: Asyn and I/O intr scanning Eric Norum
Asyn and I/O intr scanning Hinko Kocevar
Prev: synApps/vme-2-7/vmeApp/src for RTEMS (using EPICS libCom/osi Library) required Heinz Junkes
Next: CA gateway dies without error message Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Asyn and I/O intr scanning Eric Norum
Next: Re: Asyn and I/O intr scanning Eric Norum
