1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: sCalcout - again
To: Kurt Goetze <[email protected]>
Date: Mon, 23 Aug 2010 09:24:06 -0500
Hi Kurt,
I'm still having trouble with my db.  This is actually what I have.  The problem
appears to be in the definition of INAA, INBB, INCC.  When I do a caget or
camonitor of  MICE-ENV-AC-LEAK-04:calStatus.AA, I find that I have no value
stored there.  I do see the fields INAA, etc, defined in the dbd file.
The calculation works correctly, as I get the expected 1,0,-1 if I use the
uncommented CALC line.
record(scalcout,"MICE-ENV-AC-LEAK-04:calStatus") {
        field(DESC,"Water leak status determination")
        field(SCAN,"10 second")
        field(INPA,"MICE-ENV-SECPRB-01:WaterLeakStatus4")
        field(INPB,"MICE-ENV-SECPRB-01:WaterLeakValue4")
        field(INAA,"Dry")
        field(INBB,"Leak detected")
        field(INCC,"Error")
#       field(CALC,"(A=2||A=4)&&B=0?AA:(A=2||A=4)&&B=BB?1:CC")
        field(CALC,"(A=2||A=4)&&B=0?0:(A=2||A=4)&&B=1?1:-1")
        field(SVAL,"MICE-ENV-AC-LEAK-04:Status")
        field(FLNK,"MICE-ENV-AC-LEAK-04:Status.PROC")
#record(stringout,"MICE-ENV-AC-LEAK-04:Status") {
record(ao,"MICE-ENV-AC-LEAK-04:Status") {
        field(DESC,"AC unit water drip status")
        field(SCAN,"Passive")
        field(FLNK,"MICE-ENV-AC-LEAK-01:foStatus.PROC")
Any ideas?  Thanks,
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039         office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
----- Original Message -----
Date: Wednesday, August 18, 2010 9:26 am
To: Pierrick Hanlet <[email protected]>
> Hi Pierrick,
> I don't see a problem with your conditional expression.  Note that in
> the second example, your desired output will appear in the record's ".SVAL'
> field.
> Kurt
> Pierrick Hanlet wrote:
> > Hello,
> > I don't understand the online documentation regarding the string
> output of sCalcout.  I want to write
> > a string based on the results of a calculation.  Ex:
> > record(scalcout,"myrecord")
> >   field(INPA,"xxx")
> >   field(INPB,"yyy")
> >   field(CALC,"(A=1&&B=0?1:A=0&&B=1?0:-1")
> > What I would really like is
> >   field(INPA,"xxx")
> >   field(INPB,"yyy")
> >   field(INAA,"Good")
> >   field(INBB,"Bad")
> >   field(INCC,"Ugly")
> >   field(CALC,"(A=1&&B=0?AA:A=0&&B=1?BB:CC")
> > What is the correct syntax for affecting this?
> > Thanks in advance,
> > Pierrick
> > Pierrick Hanlet
> > Batavia, IL 60510
> > [email protected]
Re: sCalcout - again Kurt Goetze
Re: sCalcout - again J. Lewis Muir
RE: sCalcout - again peter.owens
sCalcout Pierrick Hanlet
Re: sCalcout Kurt Goetze
Prev: Re: msi again Ralph Lange
Next: Re: sCalcout - again Kurt Goetze
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: sCalcout emmanuel_mayssat
