1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: sCalcout - again
To: Pierrick Hanlet <[email protected]>
Date: Mon, 23 Aug 2010 09:45:43 -0500
Hi Pierrick,
INAA, INBB, etc. are input links, you will want to set your strings ("Dry", etc.)
in the corresponding .AA, .BB ... fields. SVAL will contain the string result of
the calculation, so you don't want to try to force a PV name in there. The
stringout's PV name should go into the scalcout's .OUT field, in which case
you will not need to forward link to the stringout record.
hth,
Kurt
Pierrick Hanlet wrote:
Hi Kurt,
I'm still having trouble with my db.  This is actually what I have.  The problem
appears to be in the definition of INAA, INBB, INCC.  When I do a caget or
camonitor of  MICE-ENV-AC-LEAK-04:calStatus.AA, I find that I have no value
stored there.  I do see the fields INAA, etc, defined in the dbd file.
The calculation works correctly, as I get the expected 1,0,-1 if I use the
uncommented CALC line.
record(scalcout,"MICE-ENV-AC-LEAK-04:calStatus") {
        field(DESC,"Water leak status determination")
        field(SCAN,"10 second")
        field(INPA,"MICE-ENV-SECPRB-01:WaterLeakStatus4")
        field(INPB,"MICE-ENV-SECPRB-01:WaterLeakValue4")
        field(INAA,"Dry")
        field(INBB,"Leak detected")
        field(INCC,"Error")
#       field(CALC,"(A=2||A=4)&&B=0?AA:(A=2||A=4)&&B=BB?1:CC")
        field(CALC,"(A=2||A=4)&&B=0?0:(A=2||A=4)&&B=1?1:-1")
        field(SVAL,"MICE-ENV-AC-LEAK-04:Status")
        field(FLNK,"MICE-ENV-AC-LEAK-04:Status.PROC")
#record(stringout,"MICE-ENV-AC-LEAK-04:Status") {
record(ao,"MICE-ENV-AC-LEAK-04:Status") {
        field(DESC,"AC unit water drip status")
        field(SCAN,"Passive")
        field(FLNK,"MICE-ENV-AC-LEAK-01:foStatus.PROC")
Any ideas?  Thanks,
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039 office/lab/fax http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
----- Original Message ----- From: Kurt Goetze <[email protected]> Date: Wednesday, August 18, 2010 9:26 am Subject: Re: sCalcout To: Pierrick Hanlet <[email protected]> Cc: "[email protected]" <[email protected]>
Hi Pierrick,
I don't see a problem with your conditional expression.  Note that in
the second example, your desired output will appear in the record's ".SVAL'
field.
Kurt
Hello,
I don't understand the online documentation regarding the string
output of sCalcout. I want to write
a string based on the results of a calculation.  Ex:
record(scalcout,"myrecord")
  field(INPA,"xxx")
  field(INPB,"yyy")
  field(CALC,"(A=1&&B=0?1:A=0&&B=1?0:-1")
What I would really like is field(INPA,"xxx")
field(INPB,"yyy")
field(INAA,"Good")
field(INBB,"Bad")
field(INCC,"Ugly")
field(CALC,"(A=1&&B=0?AA:A=0&&B=1?BB:CC")
What is the correct syntax for affecting this?
Thanks in advance,
Pierrick
Pierrick Hanlet
Batavia, IL 60510
[email protected]
sCalcout Pierrick Hanlet
Re: sCalcout Kurt Goetze
Re: sCalcout - again Pierrick Hanlet
Prev: Re: sCalcout - again Pierrick Hanlet
Next: Re: sCalcout - again J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
