Hi Ralph,
Thank you. I should've checked the latest branch first to see the fix.
BTW - the 3.14.11 app dev guide doesn't mention the new routine dbGetAlarm which we could be using instead of dbGetSevr. I think the app dev guide is being re-written so perhaps it will be in a form that I can edit (?) for things like this.
I also got tripped up by the changes to the breakpoint tables (I now have to load my tables separately in my st.cmd instead of including them in my app's dbd since they are not monotonic (argh!)) and the little kluge about dbBptNotMonotonic is not documented in the app dev guide though it is in the release notes. I use breakpoint tables for things where I just want to interpolate and the breakpoint tables/routines are a nice API for that.
Stephanie
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Ralph Lange
> Sent: Thursday, August 26, 2010 8:23 AM
> To: [email protected]
> Subject: Re: dbGetSevr on epics 3.14.11
> Hi Stephanie,
> thanks for reporting this issue!
> The bug was introduced by (me) merging in Codeathon 2009 work (revision 11653, 3 Apr
> 2009), so it only affects 3.14.11, no earlier versions.
> It has been fixed on the 3.14 branch (revision 12087, 19 Jul 2010).
> I created a patch file (attached), and pushed this patch to the 3.14.11+patches branch on
> Launchpad.
> @Andrew: Could you add the issue and the patch file to the Known Problems page for
> 3.14.11, please? I don't know if or how I could do web site changes remotely.
> Thanks again,
> Ralph
> On 25.08.2010 21:41, Allison, Stephanie wrote:
> > Hello,
> > I'm upgrading from 3.14.8.2 to 3.14.11 and found a problem with dbGetSevr. dbGetSevr
> used to be a prototype in 3.14.8.2 and is now a macro in dbAccessDefs.h:
> > #define dbGetSevr(PLINK,PSEVERITY) \
> > dbGetAlarm((PLINK),NULL,(PSEVERITY));
> > That ";" at the end causes problems (ie: if (dbGetSevr(plink,&severity)) break;)
> > and should be removed.
> > Thank you,
> > Stephanie Allison
- Re: dbGetSevr on epics 3.14.11 Ralph Lange
- dbGetSevr on epics 3.14.11 Allison, Stephanie
RE: derived works Jeff Hill
RE: derived works Dalesio, Leo
<2010>
2025
2026
<2010>
2025
2026
