1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: derived works
To: EPICS tech-talk <[email protected]>
Date: Fri, 27 Aug 2010 14:02:39 -0500
I would vote this discussion cease or be taken off-line at this point. I don't see how it betters the EPICS community. When/if a conclusion is reached, the result would be more appropriate to the general populace.
Dalesio, Leo wrote:
I was not referring to calling code, I was referring to replicating the functionality.
Please see.....
http://lxr.linux.no/#linux+v2.6.35/Documentation/atomic_ops.txt
-----Original Message-----
Sent: Fri 8/27/2010 1:56 PM
To: Dalesio, Leo; [email protected]
Subject: RE: derived works
Ø The code approach you are talking about here is common in linux already.
Ø Did you give them credit in your code?
There is no moral obligation for the author to give credit to the authors of
a Linux library
that he calls.
Ø Who is the author on the code you did release?
My authorship and copyright were clearly included in the source I published.
Jeff ______________________________________________________ Jeffrey O. Hill Email <mailto:[email protected]> [email protected] LANL MS H820 Voice 505 665 1831 Los Alamos NM 87545 USA FAX 505 665 5107
Message content: Correspondence
Sent: Friday, August 27, 2010 11:22 AM
To: Jeff Hill; [email protected]
Enough --- really.
Michael did not release anything or intend anything.
The issue is not resolved.
The code approach you are talking about here is common in linux already. Did
you give them credit in your code? Who is the author on the code you did
release?
Nothing was intended. And nothing is resolved.
Please take this offline.
-----Original Message----- From: [email protected] on behalf of Jeff Hill Sent: Fri 8/27/2010 11:39 AM To: [email protected] Subject: RE: derived works
One more important point.
In R3.14 we took the important step of moving all of the OS interface layers
into a
common area in libCom. In contrast, in the past I maintained some of them in
with the
CA client library because the CA client library was the only part of base
that was portable
at that time. The consolidated approach makes porting EPICS to a new OS
easier.
Michael has in his published version of EPICS placed his derived version of
my source code into
libCom. His derived code now occupies exactly the same niche in libCom that
my original version
does in the decapitated CVS trunk.
Note that the Michael's derived version neither currently works correctly
nor makes any
attempt to conform to the interface that my work in the decapitated CVS
trunk requires.
Some people may ask this question; what is the problem with what Michael has
done, he
can maintain his version and Jeff can maintain his version and we can all be
happy. The
problem with that approach is that porting EPICS is now harder because I
would be
forced to maintain private copies of at least some of the OS interface
layers in CA.
Something that I am definitely not in favor of doing.
Sorry about the interruption,
Jeff
[email protected]
Message content: TSPA
On Behalf Of Jeff Hill
Sent: Thursday, August 26, 2010 10:41 AM
To: 'Dalesio, Leo'
Cc: [email protected]
Ø I'll contact my legal department today
I hope that you find this to be constructive.
This is a relatively small piece of code, and with enough effort it is
always possible to
take the concepts and write a completely new code (it really helps to have
the original ideas
and the original source code to look at). Maybe it's even strictly legal to
take the low road.
I think the wider issue is this; we get to choose, we can work together or
duplicate effort
creating functionally equivalent codes. Hence my feeling compelled to
consume some
bandwidth to discuss the issue on tech-talk.
Jeff
[email protected]
Sent: Thursday, August 26, 2010 10:04 AM
To: Jeff Hill
>Point of fact, LANL copyright and my authorship are clearly stated within
>the original
>source code.
Some other points of fact.
Strictly speaking - it is a work that was based on the concepts not copied.
No author was listed - not you nor Michael.
We can have our legal departments discuss the issue.
I'll contact my legal department today. They are very helpful this way.
We'll let you know the results. We will also share them with tech-talk so
that we can all learn the strict legal interpretation of authorship. I think
this is not the first time this has struck a nerve.
RE: atomic operations in base Jeff Hill
RE: atomic operations in base Dalesio, Leo
RE: derived works Jeff Hill
RE: derived works Dalesio, Leo
Prev: RE: derived works Dalesio, Leo
Next: EDM: virtual circuit disconnect and reconnect handling Carl Schumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: atomic operations Ralph Lange
