1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EDM: virtual circuit disconnect and reconnect handling
To: [email protected]
Date: Fri, 27 Aug 2010 15:54:55 -0500
I have extended EDM to handle the protocol that we have here at Fermilab. This allows me to get values and see them update. When our equivalent of an IOC fails values stop updating and turn white like what EDM does with EPICS' PVs. So far so good. However, when our "IOC" is returned to service the values start updating again (good) but do not turn back to the original non-white color (bad). In one unfortunate case we end up with white on white text.
Originally the values did not even update after our "IOC" was returned to service. Thanks to tech-talk I was given the hint to make use of do_conn_state_callbacks() to give EDM connection state information. With the hint I got values to resume updates but not return to non-white.
Any hints about what I am missing? Just a reference to the routine within EDM that draws the value on the screen would help speed up my reverse engineering of the API for extend EDM's protocol capablitiies would help, so that I could determine what I need to be doing.
Thanks for your time.
Sincerely,
Carl Schumann
Prev: Re: derived works Josh Stein
Next: Re: GPIB and Record Advice Andrew Wagner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: areaDetector video (Was: network video) J. Lewis Muir
Next: MEDM StripTool does not show curve comment Adesh Subedi
