1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: MEDM StripTool does not show curve comment
To: [email protected]
Date: Sun, 29 Aug 2010 17:48:49 -0400
Hi All,
I am having issues with MEDM StripTool display. I have four curves on the same StripTool with four different channels. Everything is working fine except I do not see the comments I had given.
For example, for curve 0 the comment is as follows:
Strip.Curve.0.Comment         4K Coolant Supply
The  "4K Coolant Supply" does not appear in display, insted I get "analog input record". Also while launching the same StripChart I keep getting the following kind of messages in my terminal:
==== StripTool Xt Warning Handler ====
warning:
    Class: XmTextField
    Character '\160' not supported in font.  Discarded.
At times I see my given comment for some seconds and even for some minutes before it finally disappears giving "analog input record".
Any suggestions how I can get the comments?
Sincerely
Adesh
Prev: Re: GPIB and Record Advice Andrew Wagner
Next: record support not found 王林
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EDM: virtual circuit disconnect and reconnect handling Carl Schumann
