1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: compressArray
To: Kalantari Babak <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 2 Sep 2010 09:14:06 -0700
Babak,
You can use compress records with waveform records...
The compress record whenever processed buffers all of the INP waveform (only its valid values <NELM)
# Circular buffer
record(compress, "$(compressRecord)") {
        field(DESC, "Circular Buffer")
        field(SCAN, "Passive")
        field(NSAM, "$(numberOfSamplesInCompressRecord)")
        field(INP,  "$(inputWaveformRecord) NPP NMS")
        field(ALG,  "Circular Buffer")
Note: Make sure the compress record process only when the INP waveform has been updated entirely otherwise you may buffer the same values twice or more.
Maybe you can FLNK or PP them ...
Emmanuel
On 15:58 Mon 16 Aug     , Kalantari Babak wrote:
> For the synchronous data collection of SwissFEL (and its test facility)
> we make intensive use of "compress" record to locally buffer the
> acquired data in high rate at each IOC.
> In addition to single valued PVs (scalars) we need to buffer waveforms
> as well. This is especially interesting for buffering images and LLRF
> data. Before going for any development, I would like to know if anybody
> has worked on something which behaves like "compress" record (at least
> for buffering) but for waveforms (any custom record types, soft device
> supports, etc).
> Any idea is welcome.
> Babak
Emmanuel
RE: compressArray Kalantari Babak
Prev: Re: epics site off Andrew Johnson
Next: Re: msi again Linda.Pratt
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: compressArray Kalantari Babak
Next: RE: compressArray Kalantari Babak
ANJ, 03 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
