1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: compressArray
To: <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 3 Sep 2010 11:48:44 +0200
Cool! It works!
I think the record documentation is not vey explicit on this.
Anyway it does what I want. I have to be just careful with NUSE and
interpret it correctly to the number of buffered waveforms meaning: if I
have a waveform with NELM set to "k" to be buffered by a compress
record, then if NUSE of the compress record shows "m" I have "k/m"
waveforms stored already.
Babak
> -----Original Message-----
> From: [email protected]
> You can use compress records with waveform records...
> The compress record whenever processed buffers all of the INP waveform
> (only its valid values <NELM)
> # Circular buffer
> record(compress, "$(compressRecord)") {
>         field(DESC, "Circular Buffer")
>         field(SCAN, "Passive")
>         field(NSAM, "$(numberOfSamplesInCompressRecord)")
>         field(INP,  "$(inputWaveformRecord) NPP NMS")
>         field(ALG,  "Circular Buffer")
RE: compressArray Kalantari Babak
Re: compressArray emmanuel_mayssat
Prev: Re: msi again Benjamin Franksen
Next: RE: compressArray Kalantari Babak
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: compressArray emmanuel_mayssat
ANJ, 03 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
