1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: problem about use aSubRecord to handle waveform record
To: "Hu, Yong" <[email protected]>
Cc: [email protected]
Date: Thu, 9 Sep 2010 13:53:24 +0800
On Wed, Sep 08, 2010 at 08:49:51AM -0400, Hu, Yong wrote:
> Hi Tianmin,
> A few suggestions:
> 1. Are you using areaDetector package for the image acquisition? If so,
> check out the following command at st.cmd and make sure the 'NELEMENTS'
> is '640*480':
> dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/NDStdArrays.template","P=$(PREF
> IX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,TYPE=Int8,FTVL=UCHAR,NELEMENT
> S=307200")
> 2. Did you try 'cainfo image0'? What are the "Request type" and "Element
> count"?
> 3. Try 'cainfo treatedimage' and tell me the results;
> 4. I'm playing with aSub for a while. Could you send me your aSub source
> code so that I can look deeply into it to find the problem?
> Good luck,
> Yong Hu
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of wantianmin
> Sent: Tuesday, September 07, 2010 10:21 PM
> To: [email protected]
> Subject: problem about use aSubRecord to handle waveform record
> Hi all:
>        I'm using aSubRecord to handle an image(a waveform record with
> size 640*480),
>        After some process,the treated data has been output to another
> waveform record.
>        However when this IOC is running, the "top" command tell me the
> IOC consume about
>        1.5G memory(my pc has 2G memory),and only one client(an edm
> client) can connect
>        to it and display the image which has been treated. Even an epics
> gateway is running
>        as a middle layer between  IOC and client,the problem is still
> exist.
> My asubrecord db like this:
> record(aSub,"asub")
>     field(INAM,"myAsubInit")
>     field(SNAM,"myAsubProcess1")
>     field(FTA,"UCHAR")
>     field(NOA,"307200")
>     field(INPA,"image0 CA")
>     field(FTVB,"UCHAR")
>     field(NOVB,"307200")
>     field(OUTB,"treatedimage CA")
> record(waveform,"treatedimage")
> field(DTYP,"Soft Channel")
> field(FTVL,"UCHAR")
> field(NELM,"307200")
> in the process function  myAsubProcess1,even if I am doing just a simple
> work(set the waveform pv to
> a const data),the problem has no change.
> Is there some suggestions? Thanks for you help.
> wantianmin
> 2010.09.08
Hi huyong,
    thanks for you reply,
    for your suggestions,
    1 I'm sure the NELEMENTS=307200
    2 cainfo image0 and cainfo treatedimage is the same:
    State:            connected
    Host:             note.wantm:5064
    Access:           read, write
    Native data type: DBF_CHAR
    Request type:     DBR_CHAR
    Element count:    307200
    3 I delete all imaged code ,just draw a cross line in the center of
    the image and output it to the treatedimage pv.
    for there is no beam and no ccd hardware,I use another waveform pv
    (pic0)which is all 0 (307200),to take place of the ccd image
    It seems the tech-talk do not access attachment bigger than some size,
    I will send you the application later,after run st.cmd,and
    run dbpf asub.PROC 1, a cross line will be drawn in waveform pv(pic1)
    best regards
                                        wantianmin
problem about use aSubRecord to handle waveform record wantianmin
Prev: Re: Robert Soliday
Next: RE: sscan 2-6-6 does not build with cygwin DLL release version 1.7.7-1 Wang Xiaoqiang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: problem about use aSubRecord to handle waveform record wantianmin
Next: [no subject] Ahn, Si Won
ANJ, 09 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
