1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: problem about use aSubRecord to handle waveform record
To: [email protected]
Date: Wed, 8 Sep 2010 10:21:24 +0800
Hi all:
       I'm using aSubRecord to handle an image(a waveform record with size 640*480),
       After some process,the treated data has been output to another waveform record.
       However when this IOC is running, the “top” command tell me the IOC consume about
       1.5G memory(my pc has 2G memory),and only one client(an edm client) can connect
       to it and display the image which has been treated. Even an epics gateway is running
       as a middle layer between  IOC and client,the problem is still exist.
My asubrecord db like this:
record(aSub,"asub")
    field(INAM,"myAsubInit")
    field(SNAM,"myAsubProcess1")
    field(FTA,"UCHAR")
    field(NOA,"307200")
    field(INPA,"image0 CA")
    field(FTVB,"UCHAR")
    field(NOVB,"307200")
    field(OUTB,"treatedimage CA")
record(waveform,"treatedimage")
field(DTYP,"Soft Channel")
field(FTVL,"UCHAR")
field(NELM,"307200")
in the process function  myAsubProcess1,even if I am doing just a simple work(set the waveform pv to
a const data),the problem has no change.
Is there some suggestions? Thanks for you help.
        wantianmin
								2010.09.08
Prev: Re: Please do not hijack threads [was: cPCI] leige
Next: RE: Examples of synApps scaler record using asyn port driver Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS Meeting - please register soon if you may attend Dalesio, Leo
Next: Re: problem about use aSubRecord to handle waveform record wantm
ANJ, 09 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
