1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ca client get waveform pv error
To: "wantianmin" <[email protected]>, <[email protected]>
Date: Thu, 9 Sep 2010 21:28:02 -0500
Are you sure you set EPICS_CA_MAX_ARRAY_BYTES on both the server and the client machines?
Sent: Thu 9/9/2010 9:17 PM
To: [email protected]
Subject: ca client get waveform pv error
 Hi all,
I am use a edm client get a waveform pv(640*480 ),the IOC has enough
memory,but only one client can get the pv data,when another client try
to connect to this pv,the client get the error message:
CA value callback('pic1'): No data, CA status The requested data
transfer is greater than available memory or EPICS_CA_MAX_ARRAY_BYTES
But ,I set the EPICS_CA_MAX_ARRAY_BYTES to a big number(1600000000),is
there some other options need to be configured?
Thanks for your help.
wantianmin
Re: ca client get waveform pv error wantianmin
Prev: ca client get waveform pv error wantianmin
Next: Re: ca client get waveform pv error Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: ca client get waveform pv error wantianmin
ANJ, 09 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
