1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ca client get waveform pv error
To: Mark Rivers <[email protected]>, Eric Norum <[email protected]>, [email protected]
Date: Fri, 10 Sep 2010 11:36:22 +0800
ä 2010å09æ10æ 10:28, Mark Rivers åé:
Are you sure you set EPICS_CA_MAX_ARRAY_BYTES on both the server and the client machines?
Sent: Thu 9/9/2010 9:17 PM
To: [email protected]
Subject: ca client get waveform pv error
Hi all, I am use a edm client get a waveform pv(640*480 ),the IOC has enough memory,but only one client can get the pv data,when another client try to connect to this pv,the client get the error message: CA value callback('pic1'): No data, CA status The requested data transfer is greater than available memory or EPICS_CA_MAX_ARRAY_BYTES
But ,I set the EPICS_CA_MAX_ARRAY_BYTES to a big number(1600000000),is
there some other options need to be configured?
Thanks for your help.
wantianmin
Hi,Mr Mark and Mr Eric,
this is my shell command to run the ioc and the edm client,
ioc command:
#!/bin/bash
#saveredirfile.pl /home/wantm/ioc.txt
export EPICS_CA_MAX_ARRAY_BYTES=1600000000
export EPICS_CA_SERVER_PORT=5064
cd /usr/local/epics/apps/iocBoot/iocexample
./st.cmd
edm client:
#!/bin/bash
export EPICS_CA_ADDR_LIST="10.30.1.40"
export EPICS_CA_AUTO_ADDR_LIST=NO
edm -x /home/wantm/ccd_new/dmc.edl
Best regards
ca client get waveform pv error wantianmin
RE: ca client get waveform pv error Mark Rivers
Prev: RE: Re: ca client get waveform pv error Mark Rivers
Next: Re: ca client get waveform pv error wantianmin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: ca client get waveform pv error Mark Rivers
Next: Re: ca client get waveform pv error Eric Norum
ANJ, 09 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
