1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Re: ca client get waveform pv error
To: "wantianmin" <[email protected]>, <[email protected]>
Date: Thu, 9 Sep 2010 22:31:05 -0500
I am not sure how CA allocates memory, but you have set a REALLY big value for EPICS_CA_MAX_ARRAY_BYTES (1.6GB).  Perhaps you should try setting it to be just a little bigger than the largest image you will use.  Is your data 8-bit?  If so then 400000 is big enough for the 640x480 array you mentioned.
Sent: Thu 9/9/2010 10:26 PM
To: [email protected]
Subject: Fwd: Re: ca client get waveform pv error
 You have to set EPICS_CA_MAX_ARRAY_BYTES on both the server (IOC) and
client ends. On Sep 9, 2010, at 7:17 PM, wantianmin wrote:
>> Hi all,
>> I am use a edm client get a waveform pv(640*480 ),the IOC has enough
>> memory,but only one client can get the pv data,when another client try
>> to connect to this pv,the client get the error message:
>> CA value callback('pic1'): No data, CA status The requested data
>> transfer is greater than available memory or EPICS_CA_MAX_ARRAY_BYTES
>> But ,I set the EPICS_CA_MAX_ARRAY_BYTES to a big number(1600000000),is
>> there some other options need to be configured?
>> Thanks for your help.
>> wantianmin
Hi,Eric,
   thanks for your reply,
   I checked the shell command for running the IOC and the client,
   The EPICS_CA_MAX_ARRAY_BYTES is both set to 1600000000,and
   running one client is ok,but if I try to running 2 client at the
seem time,
  the second client will complain  about such error(CA value callback ...)
        wantianmin
Re: ca client get waveform pv error wantianmin
Fwd: Re: ca client get waveform pv error wantianmin
Prev: Fwd: Re: ca client get waveform pv error wantianmin
Next: Re: ca client get waveform pv error wantianmin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 09 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
