1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stream Device With Parameters
To: Gorka Ronda <[email protected]>
Date: Tue, 14 Sep 2010 15:36:12 +0200
Hi Gorka,
Please use the subject line. Otherwise your request may be ignored.
You can use protocol(param1,param2...) with up to 9 parameters (which must neither contain space nor comma at the moment, sorry). No space allowed before ( or inside ( and ).
The parameters appear as $1 ... $9 in the protocol. (Within quotes the $ must be escaped: "\$1" ... "\$9".)
I would write your example as follows:
field(INP, "@devwbc6600.proto c4(0x04,0x57) $(PORT) $(A)")
c4 {
  out 0xc0 0x04 0xfb $2 $1 0x00 0x00 0x00 0x00 "%<xor>";
You probably want to use macros for LO and HI:
field(INP, "@devwbc6600.proto c4($(LO),$(HI)) $(PORT) $(A)")
LO and HI may as well be specified in decimal here if you like.
By the way, instead of "c4" I would also give the protocol a name that someone who is not an expert in the wbc6600 (?) can understand.
Gorka Ronda wrote:
Hello everyone,
Using streamDevice, How can I run the command dbtr like a function with parameters? Something like:
Function (parameter 1, parameter 2)
How do I have to write the protocol and record? There are currently as follows:
HI = \x04;
LO = \x57;
cmd4 = \xC0\x04\xFB${HI}${LO}\x00\x00\x00\x00%<xor>;
c4 {
out "\$cmd4";
in "%*4r";
record(bi, "$(P):$(R):C4")
field(DESC, "Command 4")
field(DTYP, "stream")
field(INP, "@devwbc6600.proto c4 $(PORT) $(A)")
What I want is not to specify the values of the variables HI and LO in the archive .proto. I want to give them values when I call the command dbtr (another command to process the records?), to give these variables the hexadecimal value I want, each time I run the command.
Thanks in advance,
Gorka
RE: Stream Device With Parameters Gorka Ronda
[no subject] Gorka Ronda
Prev: [no subject] Gorka Ronda
Next: RE: Strange gateway error message Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Stream Device With Parameters Gorka Ronda
ANJ, 15 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
