1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Stream Device With Parameters
To: Dirk Zimoch <[email protected]>
Date: Wed, 15 Sep 2010 11:31:08 +0200
Sorry for not using the subject line, I have forgotten it.
If using macros, where I have to define it? And/or where can I specify its value? If I define the record like the following I get it right, but always with that values initialized with:
field(INP,  "@devwbc6600.proto c4($(HI=0x04),$(LO=0x57)) $(PORT) $(A)")
I want to specify the values of the macros each time I process the record. I get an error in IOC initialization if I put it without values:
field(INP,  "@devwbc6600.proto c4($(HI),$(LO)) $(PORT) $(A)")
When loading record instances, it says that HI and LO macros are undefined. These are the messages of IOC initialization:
$ ../../bin/cygwin-x86/wbc6600test st.cmd
#!../../bin/cygwin-x86/wbc6600test
# Set up environment
< envPaths
epicsEnvSet("ARCH","cygwin-x86")
epicsEnvSet("IOC","iocwbc6600test")
epicsEnvSet("TOP","c:/epics/wbc6600")
epicsEnvSet("ASYN","/cygdrive/c/epics/synApps_5_5/support/asyn-4-13")
epicsEnvSet("STREAM","/cygdrive/c/epics/synApps_5_5/support/stream-2-4-1")
epicsEnvSet("EPICS_BASE","/cygdrive/c/epics/base-3-14-11")
epicsEnvSet "STREAM_PROTOCOL_PATH" "/cygdrive/c/epics/wbc6600/db"
# Allow PV name prefixes and serial port name to be set from the environment
epicsEnvSet "P" "wbc6600"
epicsEnvSet "R" "Test"
epicsEnvSet "TTY" "/dev/ttyS0"
cd c:/epics/wbc6600
dbLoadDatabase "dbd/wbc6600test.dbd"
wbc6600test_registerRecordDeviceDriver pdbbase
# Set up ASYN ports
# drvAsynSerialPortConfigure port ipInfo priority noAutoconnect noProcessEos
drvAsynSerialPortConfigure("L0","/dev/ttyS0",0,0,0)
asynSetOption("L0", -1, "baud", "115200")
asynSetOption("L0", -1, "bits", "8")
asynSetOption("L0", -1, "parity", "none")
asynSetOption("L0", -1, "stop", "1")
asynSetOption("L0", -1, "clocal", "Y")
asynSetOption("L0", -1, "crtscts", "N")
asynOctetSetInputEos("L0", -1, "\n")
asynOctetSetOutputEos("L0", -1, "\n")
asynSetTraceIOMask("L0",-1,0x4)
asynSetTraceMask("L0",-1,0x9)
## Load record instances
dbLoadRecords("db/devwbc6600.db","P=wbc6600,R=Test,PORT=L0,A=0")
macLib: macro HI is undefined (expanding string     field(INP,  "@devwbc6600.pro
macLib: macro LO is undefined (expanding string     field(INP,  "@devwbc6600.pro
wbc6600:Test:C4.INP Has unexpanded macro
Can't set "wbc6600:Test:C4.INP" to "@devwbc6600.proto c4($(HI,undefined),$(LO,un
defined)) L0 0"
Error at or before ")" in file "db/devwbc6600.db" line 72
dbLoadRecords("db/asynRecord.db","P=wbc6600Test,R=asyn,PORT=L0,ADDR=-1,OMAX=0,IM
AX=0")
## Start EPICS
cd c:/epics/wbc6600/iocBoot/iocwbc6600test
iocInit
Starting iocInit
## EPICS R3.14.11 $R3-14-11$ $2009/08/28 18:47:36$
## EPICS Base built Jul 30 2010
2010/09/15 11:02:29.743 _main_ wbc6600:Test:C4: Empty link. Forgot the leading '
@' or confused INP with OUT ?
2010/09/15 11:02:29.745 _main_ wbc6600:Test:C4: Record initialization failed
-----Mensaje original-----
De: Dirk Zimoch [mailto:[email protected]]
Enviado el: martes, 14 de septiembre de 2010 15:36
Para: Gorka Ronda
CC: [email protected]
Asunto: Re: Stream Device With Parameters
Hi Gorka,
Please use the subject line. Otherwise your request may be ignored.
You can use protocol(param1,param2...) with up to 9 parameters (which
must neither contain space nor comma at the moment, sorry). No space
allowed before ( or inside ( and ).
The parameters appear as $1 ... $9 in the protocol. (Within quotes the $
must be escaped: "\$1" ... "\$9".)
I would write your example as follows:
field(INP,  "@devwbc6600.proto c4(0x04,0x57) $(PORT) $(A)")
c4 {
   out 0xc0 0x04 0xfb $2 $1 0x00 0x00 0x00 0x00 "%<xor>";
You probably want to use macros for LO and HI:
field(INP,  "@devwbc6600.proto c4($(LO),$(HI)) $(PORT) $(A)")
LO and HI may as well be specified in decimal here if you like.
By the way, instead of "c4" I would also give the protocol a name that
someone who is not an expert in the wbc6600 (?) can understand.
Gorka Ronda wrote:
> Hello everyone,
> Using streamDevice, How can I run the command dbtr like a function with
> parameters? Something like:
> Function (parameter 1, parameter 2)
> How do I have to write the protocol and record? There are currently as
> follows:
> HI = \x04;
> LO = \x57;
> cmd4 = \xC0\x04\xFB${HI}${LO}\x00\x00\x00\x00%<xor>;
> c4 {
>     out "\$cmd4";
>     in "%*4r";
> record(bi, "$(P):$(R):C4")
>     field(DESC, "Command 4")
>     field(DTYP, "stream")
>     field(INP,  "@devwbc6600.proto c4 $(PORT) $(A)")
> What I want is not to specify the values of the variables HI and LO in
> the archive .proto. I want to give them values when I call the command
> dbtr (another command to process the records?), to give these variables
> the hexadecimal value I want, each time I run the command.
> Thanks in advance,
> Gorka
RE: Stream Device With Parameters Gorka Ronda
Re: Stream Device With Parameters Dirk Zimoch
[no subject] Gorka Ronda
Prev: RE: Can devices supported in areaDetector include Jai and Imperx?(links to the data sheets ) tom.cobb
Next: Re: Strange gateway error message Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Stream Device With Parameters Dirk Zimoch
Next: RE: Stream Device With Parameters Gorka Ronda
ANJ, 16 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
