1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Strange gateway error message
To: Jeff Hill <[email protected]>
Cc: "'EPICS'" <[email protected]>
Date: Thu, 16 Sep 2010 15:27:50 +0200
Jeff,
Unfortunately I don't understand your reply.
Jeff Hill wrote:
Dirk,
The following is probably occurring.
o the ca service (the gateway) has a PV who's native type is advertised to be enumerated (i.e. menu)
Shouldn't that be: the *ioc* has a pv who's native type is advertised to be enumerated
o the ca server is fetching the enumerated state set string table application type from the ca service (the gateway). That typically occurs when the ca server attaches to an enumerated pv and it needs to initialize its cache for the enumerated state set string table.
And this:
the ca *client* is fetching the enumerated state set string table application type from the gateway. That typically occurs when the ca *client* attaches to an enumerated pv...
o the ca service (the gateway) is providing a response data type which
	does not have a GDD primitive type that is (scalar or array of)
	string.
I completely don't understand this sentence. The gateway fetches the native type from the ioc and provides a string or a number depending on the request type of the client, right?
o this is not a useful response for the server so it is printing a
	(could be easier to understand) message
In the context where the message is printed, neither the PV name nor the contents of the string or enum table seem to be known. Furthermore the function returns void and does not trow exceptions. Thus the caller who might have these information cannot know about any problems and cannot provide a useful context.
o once this happens I doubt that the server will successfully provide
	the enumerated string table meta data to its clients
I have no idea what the client actually requested. I also don't know who the client is or which PV is affected. All useful context information is missing.
The message from the portable server could use some work so I created bug id
638288 at the launchpad EPICS site.
The root cause of this situation is possibly an issue in the EPICS gateway.
I think first an improvement in cas and gdd is necessary to allow to track down any potential bug in the gateway.
I must admit that I don’t know at the moment where one would properly enter
a bug against the EPICS gateway; probably the Mantis maintained bug tracker
entries for the EPICS gateway on the EPICS site are now deprecated?
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
-----Original Message-----
On
Behalf Of Dirk Zimoch
Sent: Tuesday, September 14, 2010 3:02 AM
To: EPICS
Subject: Strange gateway error message
Hi all, (Jeff in particular)
Sometime I see in the CA gateway log file entries like this:
filename="../../../../src/cas/generic/casPVI.cc" line number=251
Bad data type application type "enums" string conversion table for
enumerated PV isnt a string type?
Can anyone tell me what this means? Unfortunately it does not print any
context like PV name or involved enum strings. So the problem is quite
hard to debug.
The message comes from
void casPVI::updateEnumStringTableAsyncCompletion(const gdd & resp)
I suspect this may happen when the enum string set has been modified on
the IOC while the channel is connected though the gateway.
Dirk
RE: Strange gateway error message Jeff Hill
Strange gateway error message Dirk Zimoch
Prev: Re: Stream Device With Parameters Dirk Zimoch
Next: Re: controlling cross compiled build products Pelaia II, Tom
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Strange gateway error message Ralph Lange
Next: RE: Strange gateway error message Jeff Hill
ANJ, 16 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
