1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: controlling cross compiled build products
Date: Thu, 16 Sep 2010 09:30:24 -0400
Hi Andrew,
Thank you for the feedback! Your instructions work fine.
We have a port to iOS for building CA client libraries for both the simulator and devices (iphone/ipod/ipad). What is the procedure for contributing the relevant configuration files back to the EPICS community?
thanks,
tom
On Sep 15, 2010, at 4:02 PM, Andrew Johnson wrote:
> Hi Tom,
> On Thursday 09 September 2010 12:10:42 Pelaia II, Tom wrote:
>> I am using cross compiled targets to build CA client libraries, but I only
>> need the Com and Ca libraries. Is there a mechanism to control which
>> libraries get built for cross compiled targets without also restricting the
>> host builds?
> Assuming you have already built Base for the host architecture in this tree
> (typing "make darwin-x86" or similar achieves this) the simplest way would be
> 	make -C src libCom ca
> which will build everything in the libCom and ca directories for all cross-
> compiled targets configured for this host architecture.
> HTH,
> - Andrew
> The best FOSS code is written to be read by other humans -- Harald Welte
Re: controlling cross compiled build products Andrew Johnson
controlling cross compiled build products Pelaia II, Tom
Prev: Re: Strange gateway error message Dirk Zimoch
Next: Re: Stream Device With Parameters Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: controlling cross compiled build products Andrew Johnson
Next: Re: controlling cross compiled build products Andrew Johnson
ANJ, 16 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
